Old 08-29-2008, 08:34 PM
zepsongs  is offline
Posts: 130  -  iTrader: (2)
RG1570 in dual humbucker mode?
Has anyone ever wired a H-S-H guitar, specifically the RG1570 so that with the 5-way switch or by a push/pull pot that both the bridge and neck pups are both activated at the same time? Just wonder how that would sound, if it's worth the effort. Thanks.
Old 08-30-2008, 01:17 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: RG1570 in dual humbucker mode?
There are several ways to go about this. One idea would be to install a 3-way switch and wire the humbuckers to it and then use a push-pull to add the single to any combination(which would also get you all 3 pickups). The H-H selection has worked for tons of Les Paul and SG players for decades.
Old 08-30-2008, 10:25 AM
zepsongs  is offline
Thank you. I've had many H-H, S-S-H and S-S-S guitars over the last 20 years but this is my first H-S-H. I've found this and it is fairly close to what I am looking for: http://static.zoovy.com/img/guitarel...wdu_hsh5l11_02 I feel this way, I could have the best of both worlds.
My pickups are an Air Norton at the Neck, stock middle and a Tone Zone at the Bridge. Since I do not use the middle pup by itself I do not feel I would be missing anything and it would save me the trouble of having to install a push-pull pot.
Has anyone here tried this with their HSH setup and/or this pup config? If so, how did it sound? What were the pros & cons if any? Thanks a million.
rg1570 humbucker wiring
What is a mode? alex10 Guitar Lessons & Music Theory 13 07-06-2007 09:34 AM
FS: Egnater Dual Channel M4 Preamp with 4 dual ch. modules photios Classified Ads: Guitars and Gear 1 02-02-2007 11:59 AM
Mode Four neone??? brothersnowgone Gear and Equipment 24 07-29-2005 11:10 PM
mode four guitardevil2005 Gear and Equipment 4 03-31-2005 10:57 AM
Humbucker sounds tinny in split mode -- help? SBlack Pickups & wiring 7 11-16-2003 10:08 PM
