Old 02-19-2006, 08:35 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
RG2020 wiring? Help! Something is not right.
Hi,
I got a RG2020 used and someone had a EMG wired up in the bridge, and it was all messed up. I removed the EMG and put in the original V8, but something is wrong. The guitar is lower in volume than my other guitars and the Bridge pickup sounds a little muddy...also less output on both pickups.
Does anyone have a wiring diagram for the RG2020 so I can wire it up properely?
Thanks.
John
Old 02-19-2006, 08:54 PM
buddroyce  is offline
Re: RG2020 wiring? Help! Something is not right.
Did you also remember to change the 25k EMG pots with 500k pots that are used with Humbuckers?
Old 02-19-2006, 08:58 PM
ibanezcollector  is offline
Posts: 3,207  -  iTrader: (29)
Images: 24
was about to ask the same thing
Old 02-19-2006, 09:09 PM
john1880  is offline
oh. i didn't know that active pickups used different pots. i will have to try that. thanks guys.
john
Old 02-20-2006, 11:19 PM
john1880  is offline
Well, ya learn something new everyday. Thanks! Now the guitar sounds right. But i would still like a wiring diagram because the 5-way was all messed up and i would like to put it back to it's original settings.
also, What is the tiny switch for on the circuit board on the inside????
Thanks again.
john
Old 02-21-2006, 05:28 AM
horstausmforst  is offline
Posts: 663  -  iTrader: (1)
iirc, it's a phase switch for the piezos and doesn't make a difference if your running the piezos or the magnetic pickups alone; which is all you can do on a stock 2020x.
Your lucky, I will replace the pickups on mine today or tomorrow (the duncans have finally arrived, yay!), so I might draw up a quick diagram of the stock wiring.
Old 02-21-2006, 03:43 PM
john1880  is offline
thanks horstausmforst! that would be great and much appreciated. why does ibanez have EVERY wiring diagram on their website but the RG2020????
i saw that mod for using the piezos and magnectic pickups together. maybe some day...
john
Old 02-21-2006, 08:12 PM
Well, I began drawing, but it's pretty late here already And i'm almost sure I forgot something! Here's what I got so far. If you need any additional information about the wiring of the pots and/or the jacks, let me know.
Old 02-21-2006, 08:49 PM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Dude, at Ibanez.com they have this one, should help
http://www.ibanez.com/wiring/wire.asp?y=2004&w=RG1620X
edit: funny tho, are the V7s and V8s on piezo equiped ibanezes different? cause the old ones in my 570 sure werent 4 wire pups :/
Old 02-22-2006, 08:26 AM
the 2020x had the vlx91 switch, the 1620x had the ym-50 variant for HH setups. There is no diagram for a V7+V8+VLX91 setup on the page, at least I haven't found one.
The V7 in H-H axes is a 4-conductor pickup because you need that for parallel mode in position 2. Whereas on HSH axes, only the coil tap features of the pickups are used anyway, so you don't need 4 conductors. Cost cutting at its best
bridge pickup, coil tap, magnetic pickups, wiring diagram
Ibanez jem alternate stock wiring method??! Ki swordsman Pickups & wiring 7 11-24-2005 07:31 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 06:26 PM
Wiring for an RG Allen Garrow Other 7-string Guitars 5 06-29-2004 06:45 AM
Jem-Like wiring from two Humbuckers? MicJustMic Pickups & wiring 2 06-05-2003 09:26 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
