Old 09-05-2006, 10:31 PM
ZOMB13  is offline
Posts: 779  -  iTrader: (6)
RG270 single hum/volume wiring
hey board
im having some issues wiring my RG270, heres the way I have it now
i cant get it to work, all I get is static, and when I hit a string or even touch anything, i act like a killswitch, heres how I wired it.
any help? im using the stock neck hum in the bridge and wiring to a single volume pot. no tone or switches.
Old 09-06-2006, 10:37 PM
phantoms  is offline
Posts: 304  -  iTrader: (2)
Re: RG270 single hum/volume wiring
Have you got the bare wire to ground too? The red wire is the coil tap wire. Running it to ground taps the coil. Try running the bare wire to ground and leaving the red wire unhooked and taped off.
Old 09-07-2006, 01:29 AM
ZOMB13  is offline
Ok
you mean connect the bare wire to the cable the red wire is connected to now and run that to the ground?
Old 09-07-2006, 04:49 AM
ZOMB13  is offline
never mind, I found out that the wires sticking out of the pup were ripped....
Old 09-07-2006, 10:46 PM
phantoms  is offline
According to the 2000 270 wiring diagram (I used 2000 since my boy has a 2000 270DX), the white and ground wires are the humbucker wires and the red is the coil tap wire. This cuts the path to ground to use only one coil. You can look at it like this:
coil tap, wiring diagram
Wiring for DiMarzios & Ibanez VampireSoul Pickups & wiring 2 11-26-2005 10:34 PM
Wiring for DiMarzios & Ibanez VampireSoul Pickups & wiring 0 11-26-2005 05:33 PM
single dimarzio evolution wiring EvanzRG Pickups & wiring 3 09-11-2005 06:35 PM
Active Single Coil Pickup wiring for strat bobojem Pickups & wiring 1 03-20-2005 02:47 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
