Old 08-04-2006, 11:13 PM
Guitarmiester  is offline
Posts: 344  -  iTrader: (2)
RG350 wiring help
I got a Dimarzio PAF PRO and Dimarzio Super Distortion for my RG350. I want to take all 3 stock pickups out and put in the PAF PRO in neck position and Super Distortion in bridge position and leave the middle single coil empty. Can somebody help me through wiring them in?! Soldering won't be a problem. I just want to make sure the wiring is done correct. I can leave the stock 5-way switch in for coil tapping, right? I have a wiring diagram - RG350 HH Custom split diagram. Just need alittle help to make sure everything goes fine.
Also, I know I'll have to take the strings off and then restring it. Should I put something behind the trem.? Do the same thing that you'll find on here about blocking the trem. for detuning/downtuning? Thanks in advance.
Old 08-05-2006, 04:37 PM
Re: RG350 wiring help
Anybody?!?! I have both Dimarzio pickups I ordered, I want to put them in ASAP, these stock pickups SUCK!
bridge position, coil tap, coil tapping, dimarzio paf, dimarzio paf pro, dimarzio pickup, dimarzio pickups, dimarzio super distortion, neck position, paf pro, super distortion, wiring diagram
Ibanez jem alternate stock wiring method??! Ki swordsman Pickups & wiring 7 11-24-2005 07:31 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 06:26 PM
Jem-Like wiring from two Humbuckers? MicJustMic Pickups & wiring 2 06-05-2003 09:26 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
Double Edge wiring diagram needed... - Changing pickups in S armadillo Tech: Setup, Repairs and Mods 6 03-07-2001 10:04 AM
