Old 10-15-2005, 03:05 PM
ME.  is offline
Posts: 219  -  iTrader: (1)
Question
RG550 help 331/223
Hi,
I've got an RG550 and want too put Dimarzio's in. I've orderd the pups, switch and pots.
When I look at Ibanez Wiring Diagrams there's always an "331" on the volume pot and an "223" on the tone pot. Can anybody tell me what they are and what they're for?
Also I'd like to know, is every volume pot on an RG or JEM linear?
Thanks
Colin
Old 10-15-2005, 03:10 PM
Algiman  is offline
Posts: 2,552  -  iTrader: (14)
Re: RG550 help 331/223
They are capacitors. That is how high frequencies are filtered off (tone pot) or kept in the sound (vol pot).
As for log/linear pots, look again at the diagram
http://www.ibanez.com/wiring/wire.asp?y=2001&w=RG550
Old 10-17-2005, 06:07 PM
ZOMB13  is offline
Posts: 779  -  iTrader: (6)
I need some of those too, any idea where to get em?
Old 10-17-2005, 06:13 PM
Algiman  is offline
Reuse the existing ones if you are careful, otherwise any electronics supplier.
Old 10-17-2005, 06:34 PM
ZOMB13  is offline
the guitar I have dosent have them, and Radioshack (electronic supplier) is so stupid they dind't even know they carried capacitators....
Old 10-17-2005, 07:38 PM
TheToneZone  is offline
Posts: 209  -  iTrader: (0)
http://www.stewmac.com
I've ordered from this company before, good service.
Old 10-18-2005, 12:34 AM
ZOMB13  is offline
Umm, wich ones would I need to use with an Ibanez RG with a h/s/h config? and a guitar with a h/s/s/??
Old 10-18-2005, 02:54 AM
Use 0.001µF (microfarad) for treble-bleed circuits on volume controls.
0.020µF and 0.050µF are common guitar tone control caps.
The higher the value, the more bass output from the tone control at its "zero" setting.
The above is straight from the stewmac website. I don't believe these things are picky about what size, output, type, color, or otherwise, pickups they are used in conjunction with. They just have to do with the volume and tone pot functionality. I may stand corrected and someone around here can step in and talk specifics.
Mike
Old 10-18-2005, 05:48 PM
ZOMB13  is offline
ooh, ok, I get it, so I did have them all along..thanks
Old 10-19-2005, 10:28 AM
ME.  is offline
Oke, thanks for the info.
Colin
ibanez wiring diagram, wiring diagram
RG550 vs RG470 wardner Other Ibanez Guitars (including Premiums) 24 05-27-2008 07:57 PM
Wow I've got a RG550 and boy do I love it! - RG550 JamesTheDude Other 6-string Guitars (non-Ibanez brand) 18 06-17-2006 05:30 PM
RG550 Serial number question leishan Other Ibanez Guitars (including Premiums) 2 12-21-2002 11:31 PM
RG550 Pickups-What are they? Mazinger Pickups & wiring 12 12-18-2002 04:20 PM
