Pickups & wiring
Routing template or measurements for humbuckers
Pickups & wiring
12-17-2002, 12:37 PM
stratoskier
Posts: 770 - iTrader: (
Hi,
I'm working on a project converting a JS700 into something like a JS6. The mod includes converting the P90 pickups to humbuckers, and that means I need to do some routing (yikes). I'm about ready, but I can't seem to find a template online that gives good dimensions for the humbucking routing (position, size, depth...). I can make some sort of template based on another guitar, but I'd really like to see a "standard" template for comparison. I looked at one of my S540s and the routing is asymmetrical (the position of the plunge cut for the height adjustment screws differs on each side of the route). Anyone know where I can find some details on the correct routing. Anyone ever tried converting P90s to hummers?
Thanks,
Bert
stratoskier
Find all posts by stratoskier
12-17-2002, 12:43 PM
EKG
Posts: 2,280 - iTrader: (
Check
Stewmac
for templates ;-)
EKG
Visit EKG's homepage!
Find all posts by EKG
12-17-2002, 12:54 PM
stratoskier
I did check there, and it appears that they used to have online templates for pickup routing (pdf format), but they're no longer available. I presume they decided they'd rather sell you the template than give 'em away. That was in their "free info sheet" area, under "templates". Maybe they moved them somewhere else.
stratoskier
12-17-2002, 01:25 PM
EKG
How about
here
EKG
12-17-2002, 02:03 PM
stratoskier
Oooh, that's good! And I'm sure it'll be helpful for other projects. But that blueprint is for a top-route (pickguard equipped) guitar, and I really need a template for a JS style without a pickguard. I'd expect that the routes need to be a little deeper without the guard. I'll hunt around here on Jemsite and see if there any more of these goodies. Thanks, Eddie!
stratoskier
12-17-2002, 02:24 PM
EKG
The routes would be fine for a JS....just subtract the electronics cavity. If you are gonna use pick-up rings, this is fine. If you are going for direct mount pups, it will have different depths ;-)
EKG
12-17-2002, 02:35 PM
stratoskier
Oh sure, now I get it. The pickups rings essentially take up the same additional height as the pickguard would (duh). I'm all set then. I'll try and post pictures when this project is done. Thanks once again!
stratoskier
12-18-2002, 09:18 AM
stratoskier
One more question: Can someone tell me why the "plunge" routes (the deeper holes on either side of the
pickup cavity
where the mounting screws will fit) are asymmetrical? I noticed this on my S540 body, but now I see that its also the case in the Jem blueprint Eddie referred me to. The brackets on the pickups are the same on both sides, so why is the hole on the bass side of the pickup 6mm longer than on the treble side (32mm versus 26mm)? There's gotta be a reason, but I don't see it yet.
stratoskier
12-18-2002, 01:16 PM
Globbits
Posts: 677 - iTrader: (
I think its so you can screw the pickups in deeper on the bass side than the treble..
Globbits
Find all posts by Globbits
12-18-2002, 01:43 PM
stratoskier
Hmm, I'm not so sure. The
depth
of the holes is the same on both sides (in the blueprint, D=30mm on both). And it seems to me that the depth is all that matters for adjusting
pickup height
. But the
length
differs. I still don't get it. I also noticed that on an old Kramer body, the plunge cuts aren't asymmetrical like on the Ibanez. Other thoughts?
stratoskier
pickup cavity
pickup height
what kind of router is best for routing guitar bodies?
humbuckers for strat which is the best
routing rga bare knuckles
How to take the covers off your humbuckers
what are parallel humbuckers?
10:16 AM
