Old 04-22-2008, 08:48 AM
zorba128  is offline
Posts: 3  -  iTrader: (0)
S450 picking hum
Hello
I have problem with my Ibanez S450 (hsh, 5way OTAX switch, stock pickups) picking noise. It seems to be 50Hz/100Hz, its level follows volume knob setting, also it reacts to tone control just as a pickup signal. With single coil is most visible, a bit less with humbuckers, h+s and s+h configs seem to be most quiet...
Is it maybe any "common" problem, with well known solution?
I'd like to try rewire everything (provide true star grounding scheme, separate signal ground from shield ground) to try if it helps. Prior doing this, I wanted to check if current wiring follows original diagram - but I cannot find it anywhere (S450 is 1991 model, while wiring diagrams on ibanez webpage are available for models since 1994). I thought it should be similar to S470, but 5way switch seems to be wired other way...
So - anyone knows where could I find S450's wiring diagram?
And - maybe - photos of elecronic cavity of S450/S470 model?
thanks
marcin
Old 04-24-2008, 12:20 AM
mackself  is offline
Posts: 5  -  iTrader: (0)
Re: S450 picking hum
Hi, i think that the diagram of s370 (1994) could works, similar configuration v1-s1-v2 and the otax switch
Old 04-24-2008, 05:51 PM
zorba128  is offline
It appreared that wiring is quite similar to that one (and other configs with OTAX), difference is that in my guitar other section of 5way switch is used.
Other thing is that grounding scheme doesn't exactly follow diagram - some of wires are grounded at the 5way switch. Could someone with guitar matching such circuit (S370/S450/S470/S540 with OTAX and 3wire HBs) take a photo of wiring cavity?
thanks,
marcin
wiring diagram
New amp: Instant picking response. Gex Gear and Equipment 32 02-10-2008 03:19 PM
In Search Of..Picking Techniques... DavJGar Dave Weiner Official Forum Archive (SEE NEW LOCATION) 12 01-11-2006 03:28 PM
Is my picking technique flawed? Willin Guitar Lessons & Music Theory 5 10-01-2002 02:13 AM
Picking inconsistencies... nvn Guitar Lessons & Music Theory 6 07-10-2002 05:59 PM
Picking Styles - So many picking styles... Galtero Guitar Lessons & Music Theory 2 03-30-2002 08:28 PM
