Hi!
I'd like to ask for some help with wiring my S540FM. I have the stock ibanez singlecoil and two EVOs. I'd like to wire the VLX91 OTAX switch to work like the stock (bridge, bridge tapped + singlecoil, singlecoil, neck tapped with singlecoil, neck)
I am not too good at electrics, but I can read the wiring diagrams.
I have tried the following wiring setup I have found on jemsite:
and also this one:
With the later setup I got the following results:
selector in
bridge position (1): neck pickup is on, with some noise
selector in position (2), (3), (4): only the midle singlecoil is on, with huge noise
selector in
neck position (5): bridge pickup is on, with some noise
I have checked many times... I have wired everything like it is on the diagram.
The pickups are good that is for shure, and the switch is also good (i have even taken it apart to check if the contacts inside are ok...)
Pleeese help me!
