Old 08-11-2007, 01:42 AM
Zerimas  is offline
Posts: 13  -  iTrader: (0)
Saddle Radius on Edge Not Matched to Fingerboard Radius?
I have a 91' RG550 and after setting the action to my liking I've noticed that the action is perceptibly higher, albeit not by much, on the G and D strings. Is it possible that the bridge could have been unnecessarily shimmed at the factory, or am I crazy?
Old 08-11-2007, 01:44 AM
Zerimas  is offline
Re: Saddle Radius on Edge Not Matched to Fingerboard Radius?
Arg! I am a fool and I posted this in the wrong forum!
Old 08-11-2007, 05:56 AM
TheToneZone  is offline
Posts: 209  -  iTrader: (0)
that's the way the edge trems were made. also, i've yet to see one come shimmed from the factory, atleast none of the 3 i've owned.
Old 08-11-2007, 02:08 PM
Zerimas  is offline
I see; I guess I will have to get used to it. It feels a little irksome, especially after playing my Pro Line 1660 which has a Pro Rock'r on which the saddles are adjusted to perfectly match the radius of the fretboard.
Old 08-11-2007, 08:14 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
If it bothers you then just shim the other saddles to get the radius right. Then re-adjust the action. Simple enough to do.
Old 08-12-2007, 06:03 PM
Zerimas  is offline
Thanks for the tip! I figured that the bridge and fingerboard radius were not the same by default, as is often the case. I did not expect the difference in radii to feel so awkward.
edge trem, edge trems, fingerboard radius
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
Edge saddle _FR0D0 Tech: Setup, Repairs and Mods 16 04-23-2003 05:44 PM
A saddle in the lo-pro edge rattles...? - Help, B string sad darthpolster Tech: Setup, Repairs and Mods 9 12-17-2002 06:09 AM
Edge Bridge Saddle drthunder Tech: Setup, Repairs and Mods 2 11-28-2002 03:34 AM
