Pickups & wiring
Series and parallel with a EP1112 help!
Pickups & wiring
02-25-2006, 01:40 PM
marianozz
Posts: 2,221 - iTrader: (
Hi guys, I have a
Tone Zone
in the bridge, a Paf Pro in the neck, a EP1112 multipole switch, a DPDT switch, a vol pot and a tone pot and id like to wire the following settings:
pos. 1: Neck in series
pos. 2: Neck in parallel
pos. 3: Neck series + Bridge series
pos. 4: Bridge parallel
pos. 5: Bridge series
So i have normal "
les paul
" sounds in pos. 1/3/5, with the added parallel modes in 2/4.
And on top of this, id like to be able to split both pups with the single DPDT switch as shown in the 4 conductor pup guide, so i can get JS switching...
Im sure this is possible, but im having a lil trouble figuring out the EP1112, so, i cant make it work
On top of this im gonna wire the stock S1 directly to the vol pot with a switch, so i can add it to any position kinda like the EBMM Morse model, but thats easy :P
So if anyone has a diagram for series and parallel on the 1112, thatd be great
marianozz
Find all posts by marianozz
02-27-2006, 04:32 PM
Scott of Actual Time
Posts: 363 - iTrader: (
Re: Series and parallel with a EP1112 help!
marianozz
Hi guys, I have a Tone Zone in the bridge, a
Paf Pro
i just posted a link in another thread to a
wiring diagram
for this scheme. here it is again:
http://www.his.com/~sha3u/gear/2hb-parallel-stewmac.jpg
marianozz
sounds like you need a voltmeter. i have a cheap one that beeps when the two metal probes are connected. using a voltmeter, you can take any switch and figure out what poles are connected in what positions. you could also e-mail dimarzio's techs and ask them for a picture of the switch pole assignments.
marianozz
you may have to wire that by running leads from the tabs on the 5-way switch to your DPDT. any switching scheme involving parallel humbuckers is harder to wire in coil cuts because you've got to connect 3 of the 4 humbucker wires to the 5-way switch.
Visit Scott of Actual Time's homepage!
Find all posts by Scott of Actual Time
02-28-2006, 01:47 PM
marianozz
woot, dimarzio once again answered my email, and gave me a diagram with DPDT switch and all
ill post it once i get home so anyone can have it
thanx Scott, too
marianozz
02-28-2006, 04:59 PM
marianozz
please do--i'd like to check it out.
marianozz
thanx Scott, too
no problem!
03-02-2006, 08:52 AM
marianozz
Here it is man, however it seems wrong... look at the
neck pickup
, the "green" wire gets the black plastic jacket, and vice versa... the bridge is normal :/
I assume i should pay attention to the wires coming out of the pickup, so both green wires go to ground, but i emailed dimarzio back anyway to be sure...
marianozz
03-02-2006, 09:31 AM
marianozz
Here it is man, however it seems wrong... look at the neck pickup, the "green" wire gets the black plastic jacket, and vice versa... the bridge is normal :/
that's not necessarily wrong. the green wire _usually_ goes to ground, but in a complicated scheme like this, it may not work that way.
after taking a look at the diagram, the reason they're grounding the black wire on the neck pickup is because of the orientation they're installing that pickup in--with the cable coming out of the coil closest to the bridge. if the pickup were rotated 180 degrees, the green wire would go to ground.
it will make no difference in the sound.
03-02-2006, 10:52 AM
marianozz
What about the "g" (green) wire marked "black" later on?
One more, looking at it it would seem to me that the kill switch would kill the
inner coils
, right? If so, what poles should i wire to the switch so it kills the outer coils?
marianozz
03-02-2006, 02:31 PM
marianozz
umm, i don't see a green wire marked black later on.
marianozz
One more, looking at it it would seem to me that the kill switch would kill the inner coils, right?
look at the other wires coming from each of those inner coils--they're going to the hot output. the switch is not killing the inner coils, it's grounding one end of each inner coil. so the output signal from the other end will be just the inner coil of each humbucker, not both coils of each humbucker. so that switch is giving you the inner coils.
03-02-2006, 03:32 PM
marianozz
Yeah, see the "b" coming out of the neck pickup, it later got the green plastic around it...
Anyway, they wrote back with a corrected diagram, and the wire labels were backwards, here it is:
And yeah, now i got the single coil thing, i was thinking that it was sending the whole coil to ground, so the outer one was active, but now i understood it...
Well, i cleaned up the bridge today, so tomorrow ill do all the soldering and put it together
thanx man
marianozz
03-02-2006, 06:41 PM
marianozz
oh yeah--you're right.
marianozz
thanks for posting that.
it looks like they've rotated the neck pickup 180 degrees. which will work fine, and the wire colors look correct. but, since the neck pickup is rotated, the big black cable coming out of the pickup in the second diagram shouldn't be in the bottom right-hand corner, like they have it. it should be in the upper left-hand corner. so you might want to install your neck pickup that way.
03-02-2006, 07:49 PM
marianozz
Yeah, i noticed that, they rotated the inside of the pickup, but not the wires, or maybe its one of them "R" labeled pickups
anyways, ill do it tomorrow and let you know how it went...
marianozz
inner coils
les paul
neck pickup
paf pro
pole switch
tone zone
wiring diagram
what s series ibanez did herman lee play
make an ibanez rg series sound like a strat?
how did they make 24 fret s series
how much is a fender stratocaster japan series
how much is new ibanex rx series pictures
Coil Tap and Parallel?
Shredcows
Pickups & wiring
01:19 AM
got my 7620 rewired a la JS series
Drew
Other 7-string Guitars
11:21 AM
Series or parallel? Pondering the wiring of 2x12s...
Mr Orange
Gear and Equipment
05:28 PM
parallel Humbuckers
hittman7
10:51 PM
Speaker Cabinets - Series or Parallel
pri0531
Tech: Setup, Repairs and Mods
03:23 PM
07:29 AM
