Old 01-15-2010, 03:06 PM
MityKwin  is offline
Posts: 6  -  iTrader: (0)
Should I Split/Parallel a Fast Track 1???
So I'm about to wire up my S670PB with new Dimarzios and I'm adding 2 mini switches for series/split/parallel on the bridge FRED and neck PAF Joe but I'm not sure what I might gain by putting a switch in for the Fast Track 1 in the middle. I mean, it's pretty much voiced like a single anyway right? I don't know... tell me what you think.
BTW... if it matters, I'm wiring it up with standard 5 way switching as opposed to the Ibanez 5 way... No splitting on 2 & 4.
Thanks for your opinion!
Old 01-15-2010, 04:31 PM
vai n maiden  is offline
Posts: 215  -  iTrader: (4)
Reviews: 3
Re: Should I Split/Parallel a Fast Track 1???
I'm planning on doing it myself (although mine will be in the neck position). I don't see why not! The worst that can happen is you don't like it and leave it in series!
Old 01-15-2010, 05:47 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
ive tried it, dont bother.
Old 02-05-2010, 08:54 AM
Reviews: 3
I've now tried it and am in agreement with Jaden. It sounds like a single to start with and just gets the teeeensiest bit brighter in parallel, barely noticable.
Old 02-05-2010, 11:01 AM
Yamadron  is offline
Posts: 105  -  iTrader: (0)
Reviews: 3
So the sound of the Fast Track 1 is almost the same in parallel and coil split.. That will change my plan
Thanks MityKwin for such a question
Old 02-08-2010, 02:03 PM
MityKwin  is offline
I was trying to take Jaden's advice and not bother, but then I ended up wiring the new switch a little funky and had the Fast Track split unintentionally and it was actually different enough that I liked leaving the option there... It's a bit more "tubular" if that makes sense. It gets brighter but it also gets a little but more middy giving it just a little bit of "squonk". I didn't notice it much at all with any dirt on the sound but with a clean sound it was there...
coil split switch, dimarzio fast track, pick up selection switch, s series
FS: DiMarzio Fast Track 1 reguv760 Classified Ads: Guitars and Gear 5 07-26-2009 06:27 PM
coil split and parallel? Shredragrammaton Pickups & wiring 3 02-07-2009 12:06 AM
Whats your favorite AN/TZ combined sound? Out of phase? split coil? parallel? Rotti Pickups & wiring 5 01-19-2009 06:55 AM
Fast-track 1? big h Pickups & wiring 7 04-18-2003 07:46 PM
DM. Fast Track I or II, SD. Little ´59 or SD. Hot Rails? urkoman Gear and Equipment 11 10-31-2002 10:39 PM
