Old 10-13-2006, 06:30 AM
isida.d  is offline
Posts: 299  -  iTrader: (0)
Silver wire between EMG pots not long enough :(
Hey everyone,
I bought a emg 81 some weeks ago, and i'm going to put it in now, but i have noticed that the silver wire that goes between the pots (not the black covered one), that has the green thing half way down the line isnt long enough to reach so i can put the pots in , its out by about 1cm.
How can i extend this wire and how should i go about doing it.
I hope my message made sense. I've installed passives before but not actives.
regards,
daniel
Old 10-13-2006, 06:37 AM
EL-CeeDee  is offline
Posts: 484  -  iTrader: (0)
Re: Silver wire between EMG pots not long enough :(
HI there,
I'm not familliar with the wiring in question, but is it possible to replace the wire ? If not just solder a new wire to the end. Seems easy ?
Greets!
Old 10-13-2006, 08:04 AM
LonePhantom  is offline
Posts: 5,366  -  iTrader: (6)
Reviews: 98
I've done this with two RGs. Just get rid of that wire and replace it with a longer wire. You can use some insulated wire from memory too so then it's protected more.
Old 10-13-2006, 08:49 AM
isida.d  is offline
whats the go with that green bauble looking thing on the wire, and do you need to replace that too? infact what is that thing supposed to do?
And yeah the guitar i'm installing it in is a RG570
Old 10-13-2006, 08:52 AM
ibanez2005  is offline
Posts: 910  -  iTrader: (0)
Get some wire from your local hardware store and extend it, as long as its insulated you are ok, i personally wouldnt even try replacing a pickup wire from the pickup end in case you melt it with the iron. Just solder an extra bit of wire onto it.
Old 10-13-2006, 08:56 AM
isida.d  is offline
lol i am a bit thick today... the green thing is a capacitor (doh).
heres a pic
the amount of slack on that thing is rediculous....
the black wire might reach ... tho i hope i dont have to extend that one too -.-
Old 10-13-2006, 09:00 AM
Yeah, youll have to extend the Capacitor wire, just solder another bit to it, same with the black one. Its best to use insulated wire to be on the safe side.
Old 10-13-2006, 09:04 AM
isida.d  is offline
i'm a electronics noob... what happens if you dont use insulated wire? and whats the difference visually? just a coating or casing like a passive's black wire tubing before you take out the coloured wires to solder or something else...?
Old 10-13-2006, 09:18 AM
Right. Take notes, there will be a test at the end.
The wires insulation colours make no difference to sound or tone, its basically so we can distinguish between live and neutral, e.g Red = Hot/positive, Black = cold/Negative. Its important to insulate them so they dont touch and cause a short circuit between components such as the capacitor and pots.
So just to recap - the colour of the insulation is so we/you can easily find out whether they are postive/negative or other.
Its best to have everthing insulated as it cuts down the chance of a short circuit and also can shield from noise.
Old 10-13-2006, 09:20 AM
isida.d  is offline
Right, thanks for the info.
Chances are when my father gets back hell probably know some of this electronics stuff already, he does enough electronics work for car related stuff at work.
I guess i didnt want to take his knowledge for granted :P
Old 10-13-2006, 09:23 AM
Make sure to "tin" your connections before you start to solder bits together. Thats basically putting some solder on the ends your gonna solder together, this cuts down the chance of burning out components.
Old 10-13-2006, 09:26 AM
isida.d  is offline
Ok will do, chances are ill probably come back here if i have any questions about installation, but i'm sure i have it 99% down anyway as far as where i'm soldering stuff. the only thing i might be wrong about is the switch but thats easy to fix and find out if i get it wrong once.
Old 10-13-2006, 09:27 AM
The Fender 5 way switches are the hardest ive worked on, total crazy. Good luck anyway mate.
EMG HZ and DImarzio wire colors? afireinside Pickups & wiring 1 09-08-2006 11:25 PM
wtb emg 85 and 81 set with or with out pots guitarshredder7 Classified Ads: Guitars and Gear 5 07-30-2005 06:54 PM
Solid Silver Wiring Kemono Pickups & wiring 2 06-17-2005 10:19 AM
25k push/pull pot with EMG - How do I wire this up?? ChrisReedSmith Tech: Setup, Repairs and Mods 3 10-16-2001 03:30 AM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 01:59 PM
