Old 12-19-2006, 07:17 AM
Big Job  is offline
Posts: 385  -  iTrader: (0)
Simple wiring question.....A single PAF Pro
Hello,
my strat project is almost complete and I need some help on wiring up the single PAF Pro Humbucker thats going into the bridge.
There is only going to be a volume contol for this guitar NO tone knob. There are 4 wires coming out of the PAF Pro so does anyone know how to wire her in? Or have a link to a web site that has the instructions??
Any help/advide would be much apprechiated.
Merry Christmas, Big Job.
Old 12-19-2006, 07:27 AM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
Re: Simple wiring question.....A single PAF Pro
Heres what i found and seems right to me, if its dimarzio, i think you wire green and bare and put that to ground, and for the black and white i think you just not soder them to anything (i dont know if you attach them both together) cover them with shrink wrap if you can cause electrical tape gets goey and messy. and the hot (red) to the middle lug on the volume pot, the 3rd goes ground and first goes to the jack and ground to the ground on the jack. I hope this works!
Old 12-19-2006, 01:43 PM
_FR0D0  is offline
Posts: 528  -  iTrader: (0)
do you want to put a switch on it to have some coils combinations or not?
Old 12-19-2006, 02:29 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
green/bare=ground
black/white=soldered together and tapped/shrinkwrapped
red= hot
power should be to the center of the volume
ground one lug to the side..solder
the other side pickups red wire
Old 12-19-2006, 02:59 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Green and bare go to ground (back of pot)
Red goes to the input of the volume pot
Black and white are soldered together, and preferably covered in heatshrink tubing.
Old 12-19-2006, 03:18 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
yep, waylay is right !
unless by some small chance you wanted to run it in parallel ? like Mr Paul Gilbert !
in which case
Red + White = soldered together are hot
Green + Black = soldered together are ground
the braid (shield) still goes to ground (back of the vol pot)
its a bit cleaner and has more of a stratty twang, it has a bit less output but more definition.
Old 12-19-2006, 03:31 PM
_FR0D0  is offline
you can put a pull switch/volume pot for a serial parallel selection, for two hum cancelling sounds
Old 12-20-2006, 04:40 AM
Big Job  is offline
Guys,thanks for all your help on the subject! When she is finished I will upload some pictures and some sound files!
(again) Merry Christmas,
Big Job
paf pro, paul gilbert
RG270 single hum/volume wiring ZOMB13 Pickups & wiring 4 09-07-2006 10:46 PM
Simple Wiring Schematic Needed.... jclogston Pickups & wiring 16 02-22-2006 05:26 PM
single dimarzio evolution wiring EvanzRG Pickups & wiring 3 09-11-2005 06:35 PM
quick wiring question AARRGGHHH Pickups & wiring 2 04-18-2005 03:02 AM
Jem Single question... Jay Satriani JEM and Universe Guitars 5 12-01-2001 01:59 AM
