Old 03-08-2007, 06:06 AM
jlander  is offline
Posts: 77  -  iTrader: (0)
SOUND TWEAK - installed V7 S1 and V8 - neck and single position
Hi, i recently installes a V7 S1 and V8 pickups.
First i had the RG270 with INF pickups and the S1 and it sounded fine. I installed the V7 and V8, and only in one switch position sounds really tweak, thin with no body. Its the position between the neck and middle ones.
First i guessed a bud connection, bad soldering... but i checked, it seems fine. I checked the original RGX70 wiring diagram and its ok.
What can it be? does the V7 sounds like that on single position?
Whats the difference between the red and white cable in the humbucker? used ecah by themselves these pickups sound good,but these humbucker as single with the other single... sounds bad.
It didnt happend with the INF pickups.
Thanks!
inf pickups, wiring diagram
Transcript of Aussie Vai I'view (didnt know where to put it) TheOrangeChannel JEM and Universe Guitars 16 07-26-2006 12:52 AM
neck evo in 7v installed wrong from the factory? - i think t shawn Tech: Setup, Repairs and Mods 16 05-31-2004 05:45 PM
Can I place a single coil in the neck position of an RG? Lauri M Tech: Setup, Repairs and Mods 6 06-07-2003 07:54 AM
Dimarzio Blaze single coil - in neck position of rg2027xvv one less than none Tech: Setup, Repairs and Mods 1 07-17-2001 05:19 PM
Finally found a 7 string Single Coil - ...installed it today kennydoe JEM and Universe Guitars 0 04-12-2001 04:34 AM
