Old 03-13-2003, 03:19 PM
Maelstrom  is offline
Posts: 14  -  iTrader: (0)
Stereo Outputjack... EMG707 in RG7620 or UV...
I've been thinking, I bought a EMG707 and I noticed that the stereo-output provided with the pickup was way to short to use in my RG7620. Is the stock RG7620 a stereo-output and can I use it?
How did u guys do when encountering this problem?
Thanks!!
Old 03-14-2003, 12:37 AM
7LightWithOutHeat7  is offline
Posts: 84  -  iTrader: (0)
i pretty shure the out put jack in your 7620 is stereo look to see if it has 3 conection points and if it dose your good to go
Old 03-14-2003, 12:44 AM
Akhenaten  is offline
Posts: 728  -  iTrader: (1)
Thought they were usually mono. If it's not stereo, they are available. Allparts has them, and they are fairly common to get, as many guitars use the barrel type jacks. Allparts catalog part number that jack is EP 0152-000. When wiring it up, the shortest contact is the output, the second-longest contact is where you solder the battery connection, and the longest is the ground...hope this helps.
