Pickups & wiring
Strange hum on EMGs
Pickups & wiring
02-15-2007, 11:36 PM
C.Thep
Posts: 3,050 - iTrader: (
Strange hum on EMGs
I did the 18v mod and it did create a little more noise as expected but then suddenly the buzzing got really loud Everytime I touch the strings with my palm, the strings hum even more, and they hum even louder when I push the down closer to the pickup.
Help
C.Thep
Find all posts by C.Thep
02-16-2007, 12:20 AM
RSVampire
Posts: 1,813 - iTrader: (
Re: Strange hum on EMGs
sounds like a grounding problem...
triple check all your wiring and
wiring diagram
to make sure nothing came loose or is touching something else.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
02-16-2007, 08:02 PM
C.Thep
Thats what I thought, but EMGs aren't grounded. I checked it, and everthing seems well.
I doubt it, but the pot is really really old and scratchy, could that possibly cause it?
C.Thep
02-16-2007, 08:06 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Hmmm... that is strange.
Was there a noticeable hum before you did the mod?
jaxadam
Find all posts by jaxadam
02-16-2007, 08:07 PM
C.Thep
nope.
C.Thep
02-16-2007, 08:13 PM
jaxadam
Classified Watchdog
Very interesting.
What EMGs?
jaxadam
02-16-2007, 08:21 PM
C.Thep
dual 85s
C.Thep
02-16-2007, 08:28 PM
jaxadam
Classified Watchdog
Man, I have no idea...
Must be something with the wiring, or it could be a bad pot. I might have a good one laying around here I could send to you and you could try that.
jaxadam
02-16-2007, 08:32 PM
goalkpr101
Posts: 70 - iTrader: (
I dont know if this will help or not but I just installed a
Kerry King
set and had the same problem. Looked close at the diagram and it required me to ground both the 85 and 81 to the volume pot. That fixed it. I think EMG says that they require almost no grounding.
Peace
goalkpr101
Find all posts by goalkpr101
02-17-2007, 01:33 AM
LonePhantom
Posts: 5,366 - iTrader: (
Reviews: 98
That's strange, I've done the 18 volt mod in one of my axes with no problems. I just did the linked up 3 battery clips si I can reverse it and no noise either way.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
02-17-2007, 01:42 AM
C.Thep
okay, I switched the bridge and the
neck pup
, and I confirmed that only one of the pickups is buzzing.
I returned back to using a single 9v, and there is still hum.I also put in a fresh battery.
One piece of information that might be significant is that I only had that one 85 by itself without the
neck pickup
for a while, while it was on the 18v mod. Could this have damaged it?
C.Thep
02-17-2007, 09:59 AM
Demiurge
Posts: 883 - iTrader: (
Okay, so one of the pickups is new.... did you check to make sure the quik-connect plug is going the right way on the new pickup?
Demiurge
Find all posts by Demiurge
02-17-2007, 12:52 PM
C.Thep
yes sir, both of them are correctly installed
C.Thep
02-24-2007, 11:11 PM
C.Thep
Bump
EMG tech support isn't very helpful
C.Thep
02-26-2007, 10:37 PM
C.Thep
please
C.Thep
kerry king
neck pickup
neck pup
wiring diagram
emgs are the best
how to route for emgs 707
how to wire stereo jack for emgs
emgs or dimebucker?
how to install emgs!
FS: RGA 121 NTF w/ Duncan Invader Installed PLUS EMGs
Clypher
03:13 PM
EMG's?
dex_ibanez
09:15 PM
can EMG's be versitile?
Mr. S
Pickups & wiring
10:46 PM
RG620X - Installing EMGs... ???
JiMoSiTY
Pickups & wiring
10:13 AM
EMG'S in a Universe
Given to Fly
Pickups & wiring
05:34 PM
04:46 AM
