Old 12-09-2006, 02:11 AM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Strange Problem - Need Help ASAP!
Hey guys, I did a complete rewire of my RG550 (which has an X2N/S1/Air Norton combo), for I was sometimes experiencing some cracks and pops. Well, after I had wired it all, everything was working fine, except for position 1. (Keep in mind, I have the guitar wired the way it is stock, with positions 2 and 4 offering a coil tap, etc)
Whenever I put the switch into position one (supposed to be bridge pickup at full power), my X2N sounds VERY weak and thin. I've checked all of the wiring, and I've even tried wiring the X2N without the coil tap. What is going on here? Why is my X2N not outputting anymore?
Thanks
Old 12-09-2006, 02:45 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: Strange Problem - Need Help ASAP!
Something isnt wired right, one of the coils must be grounded somewhere it isnt suposed to be.
Old 12-09-2006, 02:49 AM
waylay00  is offline
That's what I'm thinking. I just tried hooking it up straight to the output jack. Same thing...Basically, coil tapping works, but when I want to run it normally, I get like 1/10th the normal output. It's not like it's "locked" in coil tap. The coil tap sounds much stronger than the full position.
Old 12-09-2006, 03:27 AM
crevis  is offline
tap the coils with something metal to see if the're both on.
Old 12-09-2006, 03:39 AM
waylay00  is offline
Yep did that (with the trem bar as a matter of fact). Both coils seem to be on, just at a very, very low output. Like I said, it works fine in coil tap mode when I ground the black and white wires, but when I unground them and solder them together, as if I were running it in full humbucking mode all the time, that's when the output drop occurs.
Old 12-09-2006, 04:55 PM
waylay00  is offline
It's working now.
Thanks though
/thread
air norton, air norton combo, bridge pickup, coil tap, coil tapping
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma JEM and Universe Guitars 89 06-18-2007 11:57 AM
Strange problem... possibly with the truss rod? Bob_The_Moose Tech: Setup, Repairs and Mods 4 02-19-2006 06:36 PM
hmmmm strange problem here guys thoughts needed... Kev Brigden Recording Studio 10 06-29-2004 08:09 PM
JCM2000 DSL100 volume swell problem Joshka Gear and Equipment 40 04-14-2004 06:49 AM
strange happings - what's the problem with this amp! oooo Gear and Equipment 3 06-11-2001 12:41 AM
