Superswitch or not...... - Jemsite
post #1 of 6 (permalink) Old 02-04-2013, 02:28 AM Thread Starter
Ok so I have an RG7321 and I want to change out the pickups...
according to the Ibanez website its current wiring is for:
5 Way selector....
NECK - NECK (Parallel) - NECK & BRIDGE - NECK & BRIDGE (Inner Coils) - BRIDGE
So I found a wiring diagram in Dimarzios site for the same setup on an RG7620... same wiring....
So I wired it up, same as above and it wont seem to work...
Took it into the shop and they say I need a 'Superswitch' to get this config.... my question is....
If the original pickups can do this config with the factory switch, is it true I need a special switch to do the same config with Dimarzios? surely the factory switch should be able to do the job?
Sean777 is offline
post #2 of 6 (permalink) Old 02-04-2013, 03:33 AM
Reviews: 6
Re: Superswitch or not......
the factory switch installed on the RG7620 is not a standard one. That's the explanation. As far as I remember on one of the diagrams there is a code close to the swith. This is the switch reference. The internal switching is different.
If you keep the standard 5-way switch you will need an additional switch to get the neck pup coils in parallel (I did that on my 2 guitars: std 5-way switch and push-pull pot switching series - parallel).
Another option might be a ON-ON DPDT switch. Or a ON-ON-ON DPTT (3 positions) swith which allows to switch from series to split coil to parallel.
You are the one to choose!
Good luck!
satch_jr is offline
post #3 of 6 (permalink) Old 02-04-2013, 03:34 AM
Reviews: 6
BTW, the switching issues have nothing to do with the pickup brand
satch_jr is offline
post #4 of 6 (permalink) Old 02-04-2013, 04:05 AM Thread Starter
Cheers thanks for the info..... I guess what im getting stumped with is..... if it can be wired that way with factory pickups (as it is now on the RG7321), the what makes the dimarzios require a different switch?
Sean777 is offline
post #5 of 6 (permalink) Old 02-04-2013, 06:46 AM
Reviews: 6
This is the same wiring and this will require the same switch, as far as I checked the wiring diagrams below:
http://www.dimarzio.com/sites/defaul...rg7620mod1.pdf
satch_jr is offline
post #6 of 6 (permalink) Old 02-04-2013, 12:02 PM
Reviews: 12
... so those powersounds have different colored wires, but the switch IS identical between a 762x and a 7321.
in essence, to wire Dimarzio's on your 7321, one has to reference Ibanez's wiring diagram of a 762x...
Reg
reguv760 is offline
Human Verification
Stew-Mac Superswitch Wiring ChaserHUN Pickups & wiring 7 01-25-2013 06:50 AM
Superswitch question tone_connoisseur Pickups & wiring 2 11-28-2008 06:53 PM
Superswitch question tone_connoisseur Tech: Setup, Repairs and Mods 1 11-13-2008 07:00 PM
Jem wiring with Allparts superswitch Andy43 Pickups & wiring 0 03-09-2006 04:16 PM
Superswitch Question Ibateur Pickups & wiring 1 10-27-2003 08:36 AM
