Pickups & wiring
Superswitch or not......
Pickups & wiring
02-04-2013, 02:28 AM
Sean777
Posts: 302 - iTrader: (
Ok so I have an RG7321 and I want to change out the pickups...
according to the Ibanez website its current wiring is for:
5 Way selector....
NECK - NECK (Parallel) - NECK & BRIDGE - NECK & BRIDGE (Inner Coils) - BRIDGE
So I found a wiring diagram in Dimarzios site for the same setup on an RG7620... same wiring....
So I wired it up, same as above and it wont seem to work...
Took it into the shop and they say I need a 'Superswitch' to get this config.... my question is....
If the original pickups can do this config with the factory switch, is it true I need a special switch to do the same config with Dimarzios? surely the factory switch should be able to do the job?
Sean777
Find all posts by Sean777
02-04-2013, 03:33 AM
satch_jr
Posts: 245 - iTrader: (
Reviews: 6
Re: Superswitch or not......
the factory switch installed on the RG7620 is not a standard one. That's the explanation. As far as I remember on one of the diagrams there is a code close to the swith. This is the switch reference. The internal switching is different.
If you keep the standard 5-way switch you will need an additional switch to get the neck pup coils in parallel (I did that on my 2 guitars: std 5-way switch and push-pull pot switching series - parallel).
Another option might be a ON-ON DPDT switch. Or a ON-ON-ON DPTT (3 positions) swith which allows to switch from series to split coil to parallel.
You are the one to choose!
Good luck!
satch_jr
Visit satch_jr's homepage!
Find all posts by satch_jr
02-04-2013, 03:34 AM
satch_jr
Reviews: 6
BTW, the switching issues have nothing to do with the pickup brand
satch_jr
02-04-2013, 04:05 AM
Sean777
Cheers thanks for the info..... I guess what im getting stumped with is..... if it can be wired that way with factory pickups (as it is now on the RG7321), the what makes the dimarzios require a different switch?
Sean777
02-04-2013, 06:46 AM
satch_jr
Reviews: 6
This is the same wiring and this will require the same switch, as far as I checked the wiring diagrams below:
http://www.dimarzio.com/sites/defaul...rg7620mod1.pdf
satch_jr
02-04-2013, 12:02 PM
reguv760
Posts: 1,207 - iTrader: (
Reviews: 12
... so those powersounds have different colored wires, but the switch IS identical between a 762x and a 7321.
in essence, to wire Dimarzio's on your 7321, one has to reference Ibanez's wiring diagram of a 762x...
Reg
12:08 PM
reguv760
Visit reguv760's homepage!
Find all posts by reguv760
Stew-Mac Superswitch Wiring
ChaserHUN
Pickups & wiring
06:50 AM
Superswitch question
tone_connoisseur
Pickups & wiring
06:53 PM
tone_connoisseur
Tech: Setup, Repairs and Mods
07:00 PM
Jem wiring with Allparts superswitch
Andy43
Pickups & wiring
04:16 PM
Superswitch Question
Ibateur
Pickups & wiring
08:36 AM
12:24 AM
