Pickups & wiring
Sustainer - Replacing Dummy Coil with Single Coil?
Pickups & wiring
09-10-2007, 06:40 PM
F.P.R.O.
Posts: 194 - iTrader: (
Bottom Picture:
http://www.cottamguitars.co.uk/index...d=70&Itemid=97
Below shows the Fernandes driver in the
neck position
with an adjacent "dummy" coil to complete the look!
This "dummy" coil can be upgraded with a working pickup for extra versatility.
1) Can this be done with both Fernandes and Sustainiac
2) Can this be done with any single
coil pickup
3) Is there enough space in say a RG1570 to do so?
4) Will this change the sound in the single coil?
5) How is the pup selector wired to use this? (Position 1 and 2 both are the neck pup?
F.P.R.O.
Find all posts by F.P.R.O.
09-10-2007, 06:43 PM
newbieguitarmaker
Posts: 4,030 - iTrader: (
Re: Sustainer - Replacing Dummy Coil with Single Coil?
I think the sustainiac use to be able to until they made the driver an actual pickup too. I didnt know the fernandes could though...hmm makes me want one more.........
newbieguitarmaker
Find all posts by newbieguitarmaker
09-10-2007, 07:01 PM
F.P.R.O.
Oh yeah, just be like having a H-S, H-S-S but with sustainer. Keeping
neck pickup
and making it single coil (luv you single coil) wouldn't bother me, if both the sustainer and the pickup functioned properly.
F.P.R.O.
09-10-2007, 11:36 PM
-Rhaab
Posts: 479 - iTrader: (
the route for the neck pickup might have to be a bit wider under the
pickup ring
, since the single coil is wider, but mabe not, you just have to check, it is a h-s-s config, i dont think the pickup would change the sustainer or sustainer effecting pickup tone. I was thinking about this along time ago too, putting a single coil next to the sustainer driver, i guess the only way to find out is to just do it, or find someone that has done it
-Rhaab
Find all posts by -Rhaab
09-10-2007, 11:39 PM
newbieguitarmaker
-Rhaab
the route for the neck pickup might have to be a bit wider under the pickup ring, since the single coil is wider, but mabe not, you just have to check, it is a h-s-s config, i dont think the pickup would change the sustainer or sustainer effecting pickup tone. I was thinking about this along time ago too, putting a single coil next to the sustainer driver, i guess the only way to find out is to just do it, or find someone that has done it
yeah it might be wider but by that pic it doesnt seem like it, speaking of all this sustainer stuff I wanted to ask, does fernandes give you the option of push pull pots like sustainiac? because I don't really want to use the sustainiac's driver as a pickup and I rather not cut holes in my rg2570 for switches and another tone knob (also the battery would just go in the control route)
newbieguitarmaker
09-11-2007, 09:31 AM
sniperfrommars1
Posts: 3,302 - iTrader: (
Well as far as not cutting holes, i dont like using the push pull method myself for activating the sustainer its a bit slow for me, so i prefer the mini toggles.
sniperfrommars1
Find all posts by sniperfrommars1
09-11-2007, 03:40 PM
newbieguitarmaker
sniperfrommars1
I know what you mean, I just can't bring myself to make holes in my rg2570 for the toggles and the tone knob
newbieguitarmaker
09-12-2007, 03:33 AM
-Rhaab
go to fernades' website and look at the sustainer manual about push pull pots, it might be possible, my sustainer kit didnt have the manual so i got it off their site for free
-Rhaab
coil pickup
mini toggle
neck pickup
neck position
neck pup
pickup ring
how to do a herman li coil split
how to set up guitar after replacing pick ups
how to play heavy metal thru single coil?
how to replace single coil pickup cover
fernandes sustainer how work
Jem single coil?
rickcard71
03-10-2006
02:56 AM
Single coil sized pickup similar to an Air Norton?
Kindred_Spirits
Pickups & wiring
11:43 AM
Replacement Single Coil for BFP?
Dunadan
Pickups & wiring
12:22 AM
Vanderberg Single Coil pup?
Vladdrac
Pickups & wiring
10:43 AM
Suggestions for replacing a Jem Single Coil Pickup?
Lonely Raven
Gear and Equipment
01:51 PM
08:39 AM
