Old 07-14-2009, 01:10 PM
phoenixrage  is offline
Posts: 12  -  iTrader: (0)
Taking EMGs from EMG KH-21
so I found a pretty good deal on a used EMG KH-21. I should be able to just take all the peices out of it and put it in my RG (might not be able to use the solderless system) but I can just install both pickups as if I got them out of a box (i.e. using the soldering method)? this is for my RG370.
Old 07-14-2009, 03:02 PM
MarkE  is offline
Posts: 469  -  iTrader: (0)
Reviews: 15
Re: Taking EMGs from EMG KH-21
Should work just fine (not sure about coil tapping - I think you need a different EMG pickup to give you the extra wires).
Bear in mind the EMGs don't need the ground wire to the bridge.
Old 07-14-2009, 04:06 PM
well, the KH21 has a 3-way switch included, so I'd be taking out my 5-way and replacing it with the 3-way. I'm looking at the pictures on the EMG site, and I don't see why it woudln't work, I'd have to take it all apart. But its hard to tell about the pots that come with it, are specific to that kit or not.
Old 07-14-2009, 04:11 PM
themadsplatter  is offline
Posts: 18  -  iTrader: (0)
make shure you take the input jack out from the esp.you need the stereo jack to work with actives.also, use stereo cables if you dont already.
Old 07-14-2009, 04:36 PM
oh, good point.. So when I switch to these, I'll need to use a 1/4" stereo cable instead of the standard mono ones?
emg, kh-21
Taking off UV Pickguard? Spectre518 JEM and Universe Guitars 4 04-18-2007 12:17 PM
guitarbt taking forever? Mister CCJ Multimedia: Music, Pictures & Sounds 4 03-26-2007 12:01 PM
What is taking so long? FlynnRoad Music J-Custom, USA Custom & Prestige Ibanez Guitars 5 05-19-2003 01:48 PM
HELP!!! Taking my JEM on a plane. amt7565 JEM and Universe Guitars 15 03-09-2003 05:18 AM
Taking a serious brake... Jay Satriani Guitar Lessons & Music Theory 15 12-30-2001 08:56 AM
