Pickups & wiring
to replace evo bridge at my vwh
Pickups & wiring
03-19-2006, 09:49 AM
morgtahna
Posts: 84 - iTrader: (
i was looking for something to replace the bridge, i'm more than happy with the neck for cleans but the bridge is not good for rocking tunes when compared to my 77fp. So i thought i'd ask your advice for something quite similar to
paf pro
but not quite still. Something powerful yet mellow for clean works. i thought about
tone zone
but still not sure.
morgtahna
Find all posts by morgtahna
03-19-2006, 01:58 PM
guitarslinger213
Posts: 375 - iTrader: (
Re: to replace evo bridge at my vwh
breed neck is like a PAF Pro on steroids. It's a great
bridge pickup
guitarslinger213
Find all posts by guitarslinger213
03-19-2006, 04:19 PM
morgtahna
well looking at it's characteristics it should be okay, less harsh on treble like paf sometimes is, but isn't breed a bit mushy?
morgtahna
03-19-2006, 09:43 PM
Shredcows
Posts: 506 - iTrader: (
Breed neck....
It ain't the
Breed bridge
If anything, the Breed neck is similiar to the PAF Pro, but with more bass and mids. Note, the treble doesnt' change.. its still there. In the bridge, its got a lot of crunch in it, extremely dyanmic (its frightening on a clean
tube amp
) and has good bite to it. It isn't fat, more on the thin side. I did a clip of it here, I wonder if the link is still up... Note, its more crunchy than chunky (a Tonezone is chunky) and its medium output but with all the high powered pedals and amps around, does't really matter aye?
I would think the Breed BRIDGE would work better for you, based on your description. Its generally mellow sounding, not overwhelmingly powerfull but it has enough juice to rock... great GREAT cleans esp when split.
Shredcows
Visit Shredcows's homepage!
Find all posts by Shredcows
03-20-2006, 03:18 PM
morgtahna
by dimarzio pickupfinder i'm leaning towards Tone Zone :>
morgtahna
03-20-2006, 04:08 PM
Ant1981
Posts: 2,181 - iTrader: (
Strange, I would have thought that the evo would be better for rock since it's higher output. I find the
paf pros
rather lean sounding compared with the evos. The tone zone is great, I use them too, but I doubt it will solve your problem if the evo isn't rock enough for you. Perhaps the 77FP doesn't have the paf pros, maybe they were changed to something else? I've got blue evos for my 77BFB.
Ant1981
Find all posts by Ant1981
03-20-2006, 04:52 PM
rgr
Posts: 1,791 - iTrader: (
If you like the PAF Pro alot (if, as Ant said, that's what's in your FP), you might not like the TZ, it's kind of mushy on the bottom. The Norton may be your ticket, that or the Breed. If you have a DMM, plug a cord into your FP, set the switch to the bridge pickup, turn the volume all the way up, and measure across the connector on the other end of the cord, if it is around 8K, it does have PAF Pros. The Pros are good sounding pickups, I'm thinking about using one in the bridge of a HM Strat that I have, they are more open sounding than the Super 3 that was originally in there and the TZ that I have in there now. A little lower output, but I have plenty of gain, so I'm not worried about that.
rgr
Find all posts by rgr
03-20-2006, 05:21 PM
morgtahna
well my FP does have PAF's, it's 15th anniversary not modded and i just love the sound it gives me and i'd like to get same or maybe not same but equivalent sound from my vwh which i'll be gigging with (i'd rather not see my FP die you know
) but air zone/norton or super distorsion, what about them? too many pups to choose from
morgtahna
03-20-2006, 06:21 PM
rgr
Norton is great, like a TZ with really tight low end and a little less output. Haven't tried a SD, but it probably won't be as bright and transparent as the PP. I'm not a huge fan of Evos, but I really like the Evo 2 which may be your best choice, it's a good match for the Evo neck, a little tamer than a regular Evo, but still has the brightness.
Or, you may just want to throw a set of PPs in your VWH 'cause it sounds like that's what you like(?).
rgr
03-20-2006, 06:30 PM
David McCarroll
Posts: 2,049 - iTrader: (
morgtahna
Remember that the VWH has an
Alder body
, as opposed to the Basswood of your FP - there will be a subtle difference in tone from that alone. If you are handy with a soldering iron, for an experiment, why not whip the Paf Pro out of the
bridge position
in your FP and try it in the VWH - you'll find out pretty quickly whether it is the tone you are after - without risking any money on what might turn out to be the wrong choice!
Cheers
David
David McCarroll
Find all posts by David McCarroll
03-21-2006, 09:28 AM
Mr Orange
Posts: 448 - iTrader: (
...or you can look at something in the Duncan line. A Pearly Gates or an Alnico Pro, perhaps?
Mr Orange
Find all posts by Mr Orange
03-21-2006, 03:26 PM
marlb5150
Posts: 158 - iTrader: (
I suggest EVO 2. They sound excellent. a bit less output than the evolution but more clarity than the original EVO.
marlb5150
Find all posts by marlb5150
03-21-2006, 06:50 PM
ukwan
Posts: 314 - iTrader: (
www.bareknucklepickups.co.uk
- get your self a set of these, far superior to anything mass produced.
ukwan
Find all posts by ukwan
03-23-2006, 05:01 PM
morgtahna
well, i settled for blue velvet neck for middle, but the
bridge pup
is still "lost"
morgtahna
03-23-2006, 06:33 PM
RSVampire
Posts: 1,813 - iTrader: (
I have a set of Breeds. Wonderful pickups. Close enough to the Paf's to give a little classic sound but still very powerful and modern sounding. I would agree that you should get a Breed in the bridge position.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
alder body
breed bridge
bridge pickup
bridge position
bridge pup
dimarzio pickup
paf pro
paf pros
tone zone
tube amp
how do u measure a bridge
how to replace clutch of ford focus zetec
how to replace floyd rose with ibanez zr tremolo
can you replace the edge zero bridge?
Help on finding a fixed bridge for custom RG,string spacing?
Swirly
Tech: Setup, Repairs and Mods
08:24 AM
Replacing the bridge on an RG370DX
artful_junkie
09:43 AM
Is this going to be easy??? - Bridge replacement for RG421
ChrisReedSmith
09:25 AM
Replacing RB2 Bridge with an original Floyd
AlexVoyager
09:57 PM
New P'ups in my JEM - ...bridge and middle replaced...
kennydoe
11:55 PM
11:28 PM
