Old 05-26-2009, 08:56 AM
Groovy Coovy  is offline
Posts: 63  -  iTrader: (0)
Tone-Zone Problem
I am having an issue with a custom 1570 that I have been working on. I had my brother do all of the wiring and just now got it working... The Air Norton and the single coil sound pretty nice, but the Tone-Zone in the bridge sounds flat and twangy/tinny. Distortion sounds great in the other pickups, but disappears in the Tone-zone. Could it be as easy as just rotating the pickup? Wiring?
Old 05-26-2009, 09:43 AM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Re: Tone-Zone Problem
Most likely, it's wired incorrectly. Flipping the pickup around won't change the sound like that.Look for a short in the wiring or a cold/bad solder joint.
Old 05-26-2009, 09:57 AM
Thanks, toneboy!!! I'll have to have my brother take a look.
Old 05-29-2009, 09:09 AM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
or maybe the wires got mixed up and youre using only one coil (its tapped).
try touching the poles with something metallic (a screwdriver) and if it sounds thru the amp, that coil is active.
if both coils are active, maybe its wired in paralel, that could sound weaker than normal too
Old 05-29-2009, 09:52 AM
southpaw_lefty  is offline
Posts: 1,140  -  iTrader: (3)
yeah it sounds like a coil is off. make sure the black and white wires from the TZ are connected to the same point on the switch.
pickup problems, tone-zone, tonezone
Problem with Dimarzio Tone Zone and RG570 nickwarhead Pickups & wiring 1 03-22-2009 07:06 PM
WTB: DIMARZIO TONE ZONE(or AIR ZONE) and BREED NECK Roadstar Classified Ads: Guitars and Gear 6 06-19-2007 02:04 PM
Dimarzio Pickup Recommendations Needed! (Evo2,Tone Zone,Breed,Air Zone,Mo'Joe??) Destroyer Of Senses Pickups & wiring 8 07-13-2006 05:49 PM
WTT: My non f-spaced Tone Zone for a Tele Tone Zone the second eye Classified Ads: Guitars and Gear 0 05-03-2005 01:24 AM
Tone Zone, Air Zone, Norton, Fred, Or Dual Sound bobojem Pickups & wiring 9 04-22-2005 04:29 PM
