Old 09-25-2002, 10:19 AM
dgbaker33  is offline
Posts: 382  -  iTrader: (6)
USRG 30 5 way switch
Can anyone tell me what the positions are for the usrg 30 pickups? I recently acquired a used one and i am having a hard time figuering out the positions. Also, do any usrg 30 owners feel the tone zone pickup lacks high end response? I have a feeling the 5 way bridge position is not the bridge pickup. Any help is appreciated.
Old 09-26-2002, 06:09 AM
macsen  is offline
Posts: 35  -  iTrader: (0)
The pickup positions are as follows.
1) Neck humbucking
2) Inside coil of neck and inside coil of bridge
3) Neck and bridge (both humbucking)
4) Bridge humbucking and inside coil of neck
5) Bridge humbucking.
Old 09-26-2002, 06:23 AM
macsen  is offline
Concerning the bridge pickup:
Frist of all, I agree with you that the Tone Zone seems to be lacking in the high end department. It just seems to lack a bit of the clarity that I want in a lead pickup. I always have to turn up the treble and presence on my amp to make up for it, but this leads to a harsher tone than I get with a good, clear pickup. I'm thinking of switching my USRG30 over to EMG-89s. I had EMG's in a Jackson PS-4 and that was the best tone I think I've ever had.
As far as you're thoughts that position 5 may not be the bridge humbucker, check something first. When I bought my USRG used, someone had lost or stolen the plastic tip on the pickup selector. I went to the local music store and picked up a pack of Fender tips, the kind that are made for strats. I found out that the Fender tips are actually larger than the Ibanez ones, and when pushed all the way onto the end of the pickup selector, they keep bumping into the heads of the screw used to mount the switch. This kept the switch from reliably hitting positions 1 or 5, basically cutting out both of my full humbucking positions. To make the matter even more aggravating, the position was just right to let the switch click physically into position without the electrical contacts being made. It --felt-- like it switched, but the sound didn't change. The moral of this long winded bit is this: Take the tip off of your switch and see if the bridge humbucker sounds like a bridge humbucker.
Old 09-26-2002, 09:30 AM
Excellent info! I am going to try a steves special in the bridge, i have one on my jpm and like it. A bit more highend. I will also chech the switch knob. Thanks
Old 09-27-2002, 08:11 AM
BeastofLove  is offline
Posts: 795  -  iTrader: (0)
Macsen- what kind of amp are you using? I'm using a Fender DeVille 2x12 and I find the Tone Zone in my USRG30 sounds very transparent with plenty of high end. Lot's of snap and a tight low end as well. And my treble setting on the amp is usually sitting at 8 (out of 12) and the presence is at 9 (also out of 12)- basically both of those controls are only at 2 o'clock.
-Ben
bridge hum, bridge humbucker, bridge pickup, bridge position, humbucker sound, local music store, music store, tone zone
