Replaced the dead
bridge pickup in my UV7PWH with another Blaze. It sends signal out just like it should. Output is nice & hot. But it also picked up a nasty humming habit.
Specifics:
Mild but noticeable 60Hz hum which gets worse if I touch the pickup. Hum is at its worst with volume at around 5. Hum goes away completely if I run the tone control down to 0.
I followed this Jemsite schematic:
http://www.jemsite.com/tech/img/t_wd_777.gif
And I'm pretty sure I've done it accurately, though my soldering is amateurish at its very best.
Anyone experienced anything like this? Any obvious mistake(s) I may have made?
Thanks for any help or advice... this UV's been sick for a while and I'm really looking forward to getting her back on her feet.
And also, a postscript concerning the above-linked schematic: there's a ground wire not pictured in the diagram that goes to a screw in the body under the bridge pickup. Am I correct in assuming that I should tie that to the volume pot along with all the other ground wires?
