Old 12-23-2007, 10:39 PM
bdk  is offline
Posts: 278  -  iTrader: (0)
V2 Humbucker DC Resistance Question
First time using a multimeter, I think I got it right, it reads 8.6. Is that right for this pickup? Should it be higher?
Old 01-03-2008, 11:12 PM
Edwood  is offline
Posts: 106  -  iTrader: (0)
Re: V2 Humbucker DC Resistance Question
Hey there, I'm no expert, but from my notes that I found [probably here on jemsite.]... my V2 reads about 16 when I use the red and bare wires. And about 8 when I use the white and bare, as well as the red and white. [My V2 has white, red and bare wires.] My measurements aren't terribly accurate, as I don't have a digital readout... going old school with an analog needle!
You may be just reading a single coil.
My notes gleaned from jemsite and DiMarzio.com:
Pickup Resistance: how to measure
Put the red lead from you multimeter on the red pickup lead, temp. wrap the black and white together and then put the black lead on the green pickup lead.
DiMarzio wiring from their pdf:
Std wiring: connect blk & wht together, red is hot, green and bare are ground.
Hope this helps.
Zero Resistance trem question a_nxiety Other Ibanez Guitars (including Premiums) 3 11-15-2007 01:24 PM
MR HOSONO - QUICK QUESTION User010101 Comments to Ibanez 1 07-18-2007 12:36 PM
Damaged body question DrAteriusBlank Tech: Setup, Repairs and Mods 2 03-07-2007 01:26 PM
Need DC Resistance numbers for V2 pickup!!! freewheeler Pickups & wiring 0 07-13-2002 12:28 AM
Volume & Tone Pots - Measuring the resistance? (or whatever bduersch Tech: Setup, Repairs and Mods 4 12-24-2001 01:18 AM
