Old 07-07-2007, 03:15 AM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
Volume capacitors
whats the voltage rating that i should get for a capacitor for a volume pot?
and what kind should i get?
i read that 0.001microfarad is like standard
but whats 330pf ceramic capacitors thats on most ibanez wiring diagrams
Old 07-07-2007, 06:19 AM
-Rhaab  is offline
Re: Volume capacitors
i checked out some sites and i guess 330pf means .003microfarad, and 100volt capacitors should be all i need
if anyone knows something i dont please say
Old 07-07-2007, 07:40 AM
Devo  is offline
Posts: 1,482  -  iTrader: (20)
micro (u) = 10^-6
nano (n) = 10^-9
pico (p) = 10^-12
hence your missing a zero there
330pF = 0.00033uF
yup the lower the value cap the higher the frequency range it allows through.. so a 330pF will let a little less mid-high frequencies escape to teh output then a 1nF (0.001uF).. the frequencies that get through will be three times higher then with a 1nF. (an octave an a bit)
Steve
ibanez wiring diagram, wiring diagram
Stew-Mac Wiring Kit Capacitors tt0511 Pickups & wiring 2 06-19-2007 04:38 PM
Effects loop volume drop in Prosonic sanchez Gear and Equipment 3 05-31-2005 09:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger JS (Satriani Model) Ibanez Guitars 5 03-03-2005 09:26 PM
Volume Pedals trouble311 Gear and Equipment 1 03-03-2004 04:23 PM
Volume pedal for Solo boost Dan D Mahnn Gear and Equipment 7 06-21-2003 02:03 PM
