Hi!!
Just got a Washburn Nuno, one of the early ones and th epush pull doesn't seem to make any difference. The bill lawrence tone is weak and seems like a single coil is only active. I looked at the wiring and it followed
seymour duncans colour coding. I then got the details of the codes of bill lawrence pickups and wired accordingly. Now the problem has changed. In humbucker mode I get a really thin/ shrill tone and very weak and in split mode the tone is beefier and doesn't sound far off. I don't have a blue wire just red and green together for split, white as hot and black and ground.
Strangely, if my ground is connected, my hubucker reads 5 kohm in split and humbucker mode. Without my ground connected my humbucker is 11.5 k and split is something like 5.6k.
Did Bill Lawrence have different coding specifically for the nuno guitars??
Is my pickup broken?
Cheers
Col
