Old 07-24-2008, 10:56 PM
PoorJohnny  is offline
Posts: 17  -  iTrader: (0)
Question
What Does "F-Spacing" refer to when buying pickups?
What is the difference between F-Spaced Pickups and regular?
What kind will we need with our Floyd Rose, Edge, and ZR Tremolos?
Old 07-24-2008, 11:00 PM
elcid  is offline
Posts: 8,721  -  iTrader: (12)
Re: What Does "F-Spacing" refer to when buying pickups?
Old 07-24-2008, 11:10 PM
Lefty Robb  is offline
What is F-spacing?
All of our full-size humbuckers except the X2N® are available in two polepiece spacings. F-spacing refers to the wider of the two spacings. For proper string alignment and balanced output, F-spaced humbuckers should be used in the bridge position on all guitars with string spacing at the bridge of 2.1" (53 mm) or greater. On these guitars, if the nut width is 1-11/16” (43 mm) or greater, F-spaced pickups can be used in the neck position as well.
Why are there two different spacings?
A long time ago (in the 20th century, actually) the electric guitar world was divided between Gibson and Fender designs. One of the differences between the two was string spacing. In general, Gibson chose a narrower string spacing at the bridge than Fender, and therefore the polepieces on Gibson humbuckers were closer together than the magnets on Fender pickups. When guitar shops started installing humbuckers in the bridge position of Strats, it was obvious that the strings didn’t line up with the polepieces, and if the E strings were too far outside, the sound could suffer. Our first humbuckers followed the original Gibson spacing, and we call them standard-spaced. When we released our first humbuckers with wider spacing, Floyd Rose bridges were very popular. Floyd string-spacing is the same as Fender spacing, so we naturally called the new pickups F-spaced.
How do I know which spacing to use?
F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm). Although some players believe that F-spaced pickups are only for the bridge position of tremolo bridge guitars, many guitars with fixed bridges (including late 1990s Gibson Les Pauls and Epiphone LPs) should have F-spaced pickups in the bridge position. Most tremolo equipped guitars that have a nut width of 1-11/16” (43mm) or more should also use an F-spaced pickup in the neck position. If you’re replacing a bridge-position pickup and you're not sure what your string-spacing is, it's usually better to get an F-spaced model. It is not necessary for the strings to pass exactly over the center of the polepieces for best performance, but it is wise to avoid a situation where the E strings are sitting completely outside of the outer polepieces.
Do some of your humbuckers come only in one spacing?
The X2N® has solid bar polepieces that work in both normal and F-spaced applications. All 7-string humbuckers are available F-spaced only. All Parker Fly replacement pickups are F-spaced only.
Is there F-spacing for single-coils?
All of our single-coil-sized pickups are designed for F-spaced applications.
Old 07-25-2008, 12:29 AM
IbanezFreak777  is offline
Posts: 3,486  -  iTrader: (10)
Reviews: 24
Originally Posted by elcid View Post
ahahahahaha
did you draw that yourself
f-spaced, pickups, spaced pickup, spacing, tremolo bridge
ever see a "JS1000" with black gloss, no "satch" inlay and a "J" ser. # IKE560 JS (Satriani Model) Ibanez Guitars 2 04-11-2009 04:05 PM
Unpleasant buying experience with a "power seller". Inzane Vendors, Auction & Reseller Talk 16 02-02-2008 04:18 AM
Differences between "IBZ INF1/INF2" and "Duncan Ibanez" pickups? Inzane Other Ibanez Guitars (including Premiums) 1 11-03-2007 01:15 AM
USA Custom Graphic, "Road Song" / "Falling Rocks" Integrum J-Custom, USA Custom & Prestige Ibanez Guitars 2 01-16-2005 01:54 PM
