Ok, I think I figured something out.
Check this out:
Push/pull 1 is a coil cut switch that cuts both pickups simultaneously.
This should work as
Push/pull 1 down*
1 Bridge series
2 Bridge series parallel w/ neck series
3 Neck Series
Push/pull 1 up*
1 Bridge north coil
2 Bridge north coil parallel w/ neck south coil
3 Neck south coil
And then push/pull 2 when pulled up should bypass the volume and tone controls sending the pickup outputs for each of the settings above straight to the output jack.
But I am not sure about this. Can anyone tell me if this will work?
thanks,
brian
