Pickups & wiring
Where to mount 9v battery in strat?
Pickups & wiring
12-10-2012, 11:00 AM
HoosierDaddy
Posts: 319 - iTrader: (
Reviews: 7
Hello.
Hey, I have a killer strat that I love that I just stuck a Duncan Active pickup in the One hum route in the pickguard, but I don't exactly know where to mount the battery? I don't have a battery box and I stuck it under the pickguard, but if the battery runs down I might have to change strings again, etc? Is there a better way?
Tim
HoosierDaddy
Find all posts by HoosierDaddy
12-10-2012, 02:48 PM
djohns74
Posts: 591 - iTrader: (
Re: Where to mount 9v battery in strat?
HoosierDaddy
Hello.
Tim
As long as you don't leave it plugged in all the time, a battery will last FAR longer than any set of strings. Even if you keep your strings for way longer than you should, just go ahead and change the battery when you put new ones on, a couple of bucks for a fresh battery (a lot less if bought in quantity) is worth it to not have to think about it dying at an inopportune time.
djohns74
Find all posts by djohns74
12-10-2012, 04:05 PM
LonePhantom
Posts: 7,329 - iTrader: (
Reviews: 120
It'll be fine under the pickguard. Use Duracells, I found them to last the longest.
And you don't need to take the strings off. Remove the springs from the tremolo cavity, loosen the strings a bit, and you'll have enough slack to remove the pickguard enough to replace the battery.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
12-12-2012, 01:39 AM
Alan0354
Posts: 204 - iTrader: (
I have been looking at this for a while, the only place is at the back between the two springs. You're not going to find a more convenient place than that. I even try turning the piece that you screw the jack connector around to create more room inside, won't work.
I use a two sided foam tape to stick the battery to the cavity and screw the back plate back on. Works like a champ.
Alan0354
Find all posts by Alan0354
12-14-2012, 12:39 PM
HoosierDaddy
Reviews: 7
Hi Alan,
I thought about this, but I basically use my Trem which is the old style 6 hole trem as a hard tail bridge and I have 4 springs holding the trem in and I have it screwed all the way in. So, there's not enough room, but I'm going to check on it the next time I change springs. I like the bridge to be all the way down on the body for maximum sustain. I have another guitar with whammy for such trem stuff.. So, this guitar is a straight ahead screamer so to speak with just one Duncan Metal Active Humbucker loaded in the pickguard. But, I thought about this and I think it might work. Thanks man. I appreciate..
Tim
Alan0354
HoosierDaddy
12-14-2012, 12:41 PM
HoosierDaddy
Reviews: 7
Where does one get double sided foam? Please tell me I can find it at the local hardware store?
Oh, I do use Duracells and they do last the longest it seems, and you do have to remember to unplug the guitar and the battery will last forever it seems. I've have another guitar with EMG's and I like them too for their sound, but I think this Duncan just sounds better in some way.. Don't know how to describe it..
Tim
HoosierDaddy
12-14-2012, 12:48 PM
AlaskaBat
Contributor
Posts: 8,948 - iTrader: (
Reviews: 98
Yes--you can find it at Home Depot and Lowes.
Look in the windows and doors section. It's the weather seal strips you put in door and window frames.
Comes in different thicknesses and works great!
AlaskaBat
Find all posts by AlaskaBat
12-21-2012, 02:49 AM
HoosierDaddy
Reviews: 7
Alan, I just tried to see if a Battery would work inside the two springs in the trem cavity. I guess this is where you meant? Anyway, I can't do it because it woudn't work for me.. It's too shallow and the battery sticks out of the back and the back plate won't attach then.. :-(
Tim
Alan0354
HoosierDaddy
12-21-2012, 05:06 AM
Algiman
Posts: 2,620 - iTrader: (
I always thought that this was the neatest solution for a strat, it does require a little routing though. The Clapton strat:
Algiman
Find all posts by Algiman
12-21-2012, 09:32 AM
HoosierDaddy
Reviews: 7
Oh, I see now from the pic. I thought you meant to leave in just two springs and then mount inside the springs. Sorry, my bad. Yeah, that works. I thought about that myself, but then I could always just route a battery box anywhere in the guitar that would not interfere with anything else, but I do like your option here. I'm going to do that I think. Thanks man.
Oh, I love the paint job too! Killer. What's that color called if you don't mind me asking?
Tim
HoosierDaddy
12-21-2012, 09:50 AM
Algiman
There is a way to squeeze a battery in between the springs, but routing is neater and leaves the trem free. No idea what that colour is, I just found it on the net to illustrate the point.
Algiman
12-21-2012, 01:28 PM
AlaskaBat
Contributor
Reviews: 98
Tim--I think the best and neatest solution will require a little routing.
AlaskaBat
active pickup mounting
Converting your Ring/guard mount pups to Direct mount
RGTFanatic
Tech: Setup, Repairs and Mods
77
04-08-2012
06:52 PM
top mount vs bottom mount
linuxpenguin
09-19-2011
08:31 AM
From pickguard mount to body mount
vaisteen2003
02:13 PM
replacing a rear mount nut with a front mount one
Koss
12:56 AM
NI Battery
J Todd Beachler
Recording Studio
07:45 PM
05:40 PM
