Old 01-28-2013, 06:39 PM
tandersn9  is offline
Posts: 37  -  iTrader: (0)
Re: Will Dimarzio pickups fit in my RG1570?
Originally Posted by Cemges View Post
Altough, i might add that RG1570's routing differs between years. Mine is an 2006 MRR, can't be sure if it will be same with <2004 or new edge zero ones
Hmm I'll have to do some research on my serial number and see what year I have.
I'm also going to see how low I can get the stock pickups to go. I'd imagine that if I can get them to go pretty low that the Dimarzio's should fit just fine. I can't imagine that Dimarzio's would be THAT much taller than the stock pickups.
Old 01-29-2013, 09:04 AM
Cemges  is offline
Posts: 59  -  iTrader: (0)
Well, they have 2 rows of small, adustable pole pieces, so they won't cause too much magnet pull even if you keep them too close. And hey, there's something like a silicon base under pickups, you can remove a little bit of it.
Pickups for RG1570 Klassky Pickups & wiring 7 11-08-2009 11:47 PM
RG1570 with Case and Dimarzio Pickups $499.95 Homeless Classified Ads: Guitars and Gear 5 08-21-2007 11:27 AM
RG1570 Silver w/ Dimarzio Pickups + Case Homeless Classified Ads: Guitars and Gear 6 07-25-2007 08:48 PM
Ibanez RG1570-Dimarzio pickups, need advice Hunter Other Ibanez Guitars (including Premiums) 9 02-03-2006 12:50 AM
Pickups for an RG1570 Screaming Solo Pickups & wiring 6 11-19-2005 01:36 PM
