Pickups & wiring
Will Dimarzio pickups fit in my RG1570?
Pickups & wiring
01-23-2013, 12:01 AM
tandersn9
Posts: 37 - iTrader: (
I just purchased an RG1570 that still has the stock pickups in it and I'd like to replace them with some dimarzio's, possibly the Tone Zone and Air Norton, Crunch Lab and liquifire combo, or Evo's.
My problem is that after doing a little research it seems that some dimarzio's such as the Crunch Lab won't fit in the guitar because the route is too shallow. So my question is, which dimarzio pickups will fit in my guitar without having to take a router to it?
tandersn9
Visit tandersn9's homepage!
Find all posts by tandersn9
01-23-2013, 07:24 AM
andrewsfury
Posts: 1,566 - iTrader: (
Reviews: 37
Re: Will Dimarzio pickups fit in my RG1570?
tandersn9
all you got to do is try to fit them.
on mine the neck one stuck up too much and i had to slightly route the part where the ears do deeper. i used a dremel.
yours might be o.k. but again all you have to do is put them in and try.
andrewsfury
Find all posts by andrewsfury
01-23-2013, 07:53 AM
j.arledge
Posts: 2,022 - iTrader: (
31
it should fit, I have a crunch lab in my cheapo N2 and it doesn't seem any thicker than any other dimarzio. I had a 570 and the route was more than deep enough for dimarzios
j.arledge
Find all posts by j.arledge
01-23-2013, 08:19 AM
tandersn9
andrewsfury
ughh I wish there wasn't even a chance of that happening, I don't know how comfortable I feel drilling into the guitar. Was it difficult?
tandersn9
01-23-2013, 11:55 AM
american21
Posts: 29 - iTrader: (
its not helpful but i just put a duncan tb4 in mine without issue
american21
Find all posts by american21
01-23-2013, 12:14 PM
RGTFanatic
Posts: 6,110 - iTrader: (
If you look at the F-spaced pickups you'll see that Dimarzio makes them in two different heights. If you run into interference the backing plate can be switched out to a shorter one if you have another DiMarzio laying around. This will only yeild a slightly shorter pickup, but may be enough to work. The back plates are interchangeable.
Your only other options are to pick another pickup, or make the recess deeper as mentioned above.
http://www.dimarzio.com/sites/defaul...ms/DMHBdim.pdf
__________________
RGTFanatic
Visit RGTFanatic's homepage!
Find all posts by RGTFanatic
01-23-2013, 12:44 PM
tandersn9
RGTFanatic
Perfect! Thanks for that link. So I'm guessing that people that have installed dimarzio's without having to do any modification have gotten the shorter pickups. I'll have to give dimarzio a call and see if I can specify which ones I want.
tandersn9
01-23-2013, 02:11 PM
moonlight
Posts: 409 - iTrader: (
From those drawings, it looks like the coils are different thickness and the backing plate is the same.
Edit: I just measured an F spaced Crunch Lab with a dial caliper and it's .98 from the top to the mounting screw tabs.
02:27 PM
moonlight
Find all posts by moonlight
01-24-2013, 02:07 PM
LuredMaul
Posts: 804 - iTrader: (
I had to route mine to fit Evo pups as the "Bobbins" are taller than usual the others should fit just fine
LuredMaul
Find all posts by LuredMaul
01-25-2013, 09:58 AM
akosunen
Look out for pickups with thicker magnets - it might be the culprit here. It seems that at least D Activators have a double thick magnet underneath the bobbins.
EDIT Here's a figure from DiMarzio's site, I assume the taller one on the right is the one with a larger magnet
akosunen
Find all posts by akosunen
01-25-2013, 10:35 AM
Cemges
Posts: 59 - iTrader: (
F spaced bridge and normal neck will fit. STAY AWAY FROM EVOS! Baswood body + evos, and if you have a bright amp or you use much treble, well, thats unlimited feedback and noise. I personally use cables that lowers the treble, i also lower treble from my amp, and from pedal, so I can control it. Tone zone and air norton will fit nicely, crunch lab and liquifire is good if you Don't have a marshall or similar amp. But, go for Mo Joe' and something like Paf Pro for neck. It is really good, and will go nice with any amp. Btw when i did put these evos in there, it just didn't require any work.
Cemges
Find all posts by Cemges
01-25-2013, 01:29 PM
Ibateur
Posts: 3,238 - iTrader: (
The snakeoil salesman sold me tone boost cables the other day. I plugged in, and nothing came out. Turns out that silence was the improvement
I seriously did not know that there were cables out there that lowered treble. I looked it up and yeah there's high capacitance low capacitance cables out there.
Ibateur
Find all posts by Ibateur
01-25-2013, 09:35 PM
tandersn9
Cemges
Alright thanks! I will take your word for it about the pickups fitting haha. I had Evo's in my old RG350 and it was a mega chunky sounding guitar through just about any amp, I miss that guitar....
I'm thinking more about the tonezone and norton
tandersn9
01-26-2013, 04:14 AM
Ibateur
I hate the TZ in my basswood rg. Prefer the super distortion or super 3. Will be trying Breeds soon
Ibateur
01-26-2013, 06:47 AM
Cemges
Altough, i might add that RG1570's routing differs between years. Mine is an 2006 MRR, can't be sure if it will be same with <2004 or new edge zero ones
Cemges
Pickups for RG1570
Klassky
Pickups & wiring
11:47 PM
RG1570 with Case and Dimarzio Pickups $499.95
Homeless
11:27 AM
RG1570 Silver w/ Dimarzio Pickups + Case
Homeless
08:48 PM
Ibanez RG1570-Dimarzio pickups, need advice
Hunter
12:50 AM
Pickups for an RG1570
Screaming Solo
Pickups & wiring
01:36 PM
07:19 PM
