Old 03-23-2008, 01:03 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Will Dimrzio fit right into Duncan route?
I'm looking at at guitar that has direct mounted Duncan in it which I may want to put direct mount Dimarzios in. Because Duncan and Dimarzio pups have slightly different mounting tabs, I'm not sure if Dimarzios will just drop right in.
If you have any info on the subject, I'd appreciate it you would chime in. Thank you.
Old 03-23-2008, 01:11 PM
losgatosrg350dx  is offline
Posts: 848  -  iTrader: (0)
Re: Will Dimrzio fit right into Duncan route?
they should
but you can always use a dremel and shave part of the ear
i had to do this with my duncan when i tried to put them into my carvin, later i just got a bartolini so i had to kind route the entire pocket
but yeah give the mountin "tabs" a shave....but try t do a dry fit, it might fit right in
Old 03-23-2008, 02:21 PM
rty13ibz98  is offline
umm..losgatos has it backwards. if it had a duncan to begin with, a dimarzio will drop right in. the duncan route is bigger. much like direct mounted v7 and v8 pickups. the dimarzios have the smaller triangle ears and will drop richt in with rook to spare. now losgatos is correct in the vice versa. me personally, i don't use a dremel for shaving the ears down, i use either diagonal cutters or lineman pliers to nip the shape and then use a file to deburr and smooth the edges. a dremel that close to the windings...if you slip and catch the winding, either you have to rebuild that pickup or trash it. with hand tools, you'll have better control. i would avoid tin snips as the blades are too big to be fairly precise. i have even reshaped a few just with a file. more time consuming, but with prettier results. if you need to take more off, like with duncan to dimarzio, trim it, then, shape it.
rich
Old 03-23-2008, 03:03 PM
i use a reall fine little sone wheel on it, i used snipps and i bent the ends and i got really close to messing up the holes....so i like doing it with a fine stone wheel on my dremel, but either way - yeah not all pups are the same route..
thansk for the correction rty
Old 03-23-2008, 03:07 PM
that's why i use diagonal cutters or lineman pliers. it gets both sides of the ear. no bending to shear. then you just work it a bit and then it's a pretty clean break. clean it up with the file and your done.
rich
toneboy  is offline
Perfect, that's what I was hoping to hear. Thanks for the info.
Old 03-23-2008, 03:14 PM
rich
hmm ill be sure to try it, next time i need to
dimarzio pups
Wiring problems with Seymour Duncan in a JEM Christoph_JEM Pickups & wiring 6 04-14-2011 05:45 PM
Seymour Duncan TB5/GFS 59 FS/FT!!! Shreddy Krueger Classified Ads: Guitars and Gear 1 02-03-2008 05:51 AM
eMG 81/60 and Duncan Distortion (Seymour Duncan SH-6) Fornicatron Classified Ads: Guitars and Gear 2 10-10-2006 11:09 AM
FS: Seymour Duncan 7-string Duncan Custom pickup Scott of Actual Time Classified Ads: Guitars and Gear 2 04-09-2006 10:22 PM
FT/Poss FS Duncan Alnico Tele neck pickup frankfalbo Classified Ads: Guitars and Gear 2 06-03-2005 03:08 PM
