Re: Wires and a mega switch
What's the plan with the push/pull pot? coil-tapping, phase inverse, series/parallel?
I have an E Megaswitch as well as a push/pull pot in my 760 for coil-tapping. For both to work, simply wire the coil-tap wires of each pickup (b + w in DiMarzio) to a middle lug of the push-pull pot and ground the bottom lugs [looking into the cavity] while connecting the hot wire to the switch.
Reg
