Old 08-29-2008, 12:18 AM
superhairycamel  is offline
Posts: 338  -  iTrader: (0)
Question
Wiring a Dimarzio paf pro (parallel) in my RG 570 Question
Thanks guys im preparing to install this baby in the neck position so i thought id try to wire it parallel for a change.
In the information that dimarzio give you on that fold out page, it says that for Parallel:
1. Red and White go together, this is the HOT connection
2. Green and Black go together, This is the ground connection (Huh?)
3. The bare wire is of course grounded also.
So im looking at the swith in the control cavity and i look at where the wires from the original V1 pickup connect.
I see a red wire connected at the fist connection point and also the white wire connected further down, so my question is, which connection should the HOT leads from the pickup go to?
Also the green and black wires, are they simply soldered to a potentionmeter together or does the pickup get grounded through the other point in the switch?
Thanks guys i really appreciate it.
Old 08-30-2008, 12:33 AM
Re: Wiring a Dimarzio paf pro (parallel) in my RG 570 Question
pleasepleaseplease
Old 08-30-2008, 12:37 AM
CosmicDebris  is offline
Posts: 3,217  -  iTrader: (4)
go here.
http://guitarelectronics.zoovy.com/c...iringresources
Old 08-30-2008, 07:09 AM
so anywhoo i worked it out and it all works fine, doesent really sound how i expected it to, wired in parallel, great for clean but not so much for the shred stuff, ill probably rewire to series in a week or so
paf pro parallel
Question about capacitor in dimarzio wiring... ThomasBJ Pickups & wiring 1 10-30-2007 02:28 PM
Parallel wiring help StevenMikel Pickups & wiring 4 07-26-2007 11:49 PM
Parallel wiring question RG450 Pickups & wiring 0 04-25-2006 12:55 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 08:06 AM
Series or parallel? Pondering the wiring of 2x12s... Mr Orange Gear and Equipment 4 04-06-2003 05:28 PM
