Wiring Crunch Lab + Liquifire + Lace Sensor Red HSH Setup on Ibanez RG270 - Jemsite
post #1 of 7 (permalink) Old 02-22-2013, 12:47 PM Thread Starter
Hello Everybody,
For the first time, i'm going to enjoy a pick-up switch and I decided to do that on my good'ol Ibanez RG 270 !
The setup will be H/S/H with, as the thread stated :
-A Dimarzio Crunch Lab in the bridge position
- A Lace Sensor RED single Coil in the middle position
-A Dimarzio Liquifire in the neck position
I made a lot of research but I can't find the wiring diagram that matchs the setup I want.
I made a blank wiring diagram as follow
I found this on the internet regarding the dimarzios but i don't find it very helpfull as there is no place on the 5-selector to fit my Lace sensor
If Anybody would have the kindness to give me a hand on this I would be very grateful, im a total noob in regard of pickups and electronic
ps : Sorry for the wall of text in bad english xD
Cheers ! \m/
Nevy is offline
post #2 of 7 (permalink) Old 02-23-2013, 05:13 PM
Re: Wiring Crunch Lab + Liquifire + Lace Sensor Red HSH Setup on Ibanez RG270
This is the one you want here:
http://www.dimarzio.com/sites/defaul...50-2HB1VV2.pdf
The green and white from the lace sensor go to ground on the back of the volume pot. The orange goes to the 2nd terminal in on the 5/way just like the single coil in the diagram. everything else stays the same.
This will give you neck, neck split/middle, middle, middle/bridge split, and bridge for your switching...
Swirltop is offline
post #3 of 7 (permalink) Old 02-23-2013, 05:31 PM Thread Starter
wow thank you very much mate !
I was thinking of getting rid of the lace but with that diagram seems all good
Now solder time ! xD
Cheers
Nevy is offline
post #4 of 7 (permalink) Old 02-23-2013, 05:43 PM Thread Starter
here is the diagram updated if anybody needs it for further use
Nevy is offline
post #5 of 7 (permalink) Old 02-25-2013, 10:30 AM Thread Starter
I ve done the solder and it works great except that there is a mistake,
The red neck is going to the 3rd pine (not the 1st)
The red bridge is going to the 1st pine (not the 3rd)
Nevy is offline
post #6 of 7 (permalink) Old 02-25-2013, 11:04 AM
All you really had to do is turn the switch around, but if you swapped the reds you also need to swap the black and whites from each humbucker... or put the reds back and turn the switch around
Swirltop is offline
post #7 of 7 (permalink) Old 02-25-2013, 04:56 PM Thread Starter
ahah xD
I see i will then turn the switch and put the red back in place
Nevy is offline
ibanez wiring dimarzio
Human Verification
fender lace sensor Cameron1234 Pickups & wiring 3 12-26-2012 03:39 PM
Make your own Lace Sensor Dually? higure Pickups & wiring 0 10-16-2012 10:33 PM
Need help with Lace Sensor Wiring gideond Pickups & wiring 4 10-18-2011 07:06 AM
Black rg 550 with Lace Sensor Alumitone pickups.. just42dave Classified Ads: Guitars and Gear 1 10-17-2009 03:46 PM
lace sensor toma Pickups & wiring 32 12-23-2006 04:56 PM
