Pickups & wiring
wiring diagram help HHH
Pickups & wiring
03-31-2008, 12:46 PM
Ibateur
Posts: 2,947 - iTrader: (
Hi all
I need a superswitch
wiring diagram
(please) for the following
(All Dimarzio)
1 - Bridge alone
2 - One coil bridge, one coil middle (humbucking)
3- middle humbucker alone
4 - One coil middle, one coil neck (humbucking)
5 - Neck alone
If you have any combos you feel are worth trying (like one coil neck one coil bridge) please let me know. But, bottom line, I need help with the superswitch.
Bridge is TZ, mid is Protrack, Neck is PafPro
I've sent an email to support at Dimarzio.com and haven't heard back.
Muchas
Ibateur
Find all posts by Ibateur
03-31-2008, 01:07 PM
losgatosrg350dx
Posts: 848 - iTrader: (
Re: wiring diagram help HHH
http://www.dimarzio.com//media/diagrams/C.pdf
the only difference is you need a 5 way multi switch, not a regular 5 way switch and follow the same diagram, but in the 3 positions bridge over the middle section bot ground and both hots of the mid pup
losgatosrg350dx
Find all posts by losgatosrg350dx
03-31-2008, 04:41 PM
Ibateur
thanks mate, but that doesn't answer my question at all. I have looked at that, and tried to figure out how that coincides with a superswitch. brain melt.
Ibateur
03-31-2008, 06:14 PM
Jaden
Posts: 2,464 - iTrader: (
with a little jiggery pokery, this one should do it.
should give you an idea how the 4
pole switch
works anyway - it basically has no internal jumpers/switching, you do that yourself.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
03-31-2008, 06:17 PM
losgatosrg350dx
Jaden
should give you an idea how the 4 pole switch works anyway - it basically has no internal jumpers/switching, you do that yourself.
bravo jaden
losgatosrg350dx
03-31-2008, 06:33 PM
Vim Fuego
Posts: 908 - iTrader: (
Have a look at:
http://www.jemsite.com/forums/showthread.php?t=70976
post #2 I think that should cover what you want.
The diagram is for the Ibanez VLX91 switch, the super switch is the same but the layout is slighty different, the solder tags are round the circumference instead of at the sides, but, otherwise it's the same!
Jim
(Damn, somebody beat me to it!, and it's the same as my solution, curses!)
06:34 PM
. Reason: Damn
Vim Fuego
Visit Vim Fuego's homepage!
Find all posts by Vim Fuego
03-31-2008, 06:43 PM
DaniJem
Posts: 1,069 - iTrader: (
I also am interested in this cuestion about HHH diagram for my project.
I take note...
thanks!
DaniJem
Find all posts by DaniJem
04-01-2008, 01:09 AM
Ibateur
Thanks Jaden and Vim.
(If I do a search, I find myself asking the same question years ago...)
Ibateur
04-09-2008, 03:33 AM
Ibateur
My lord, soldering these connections is driving me bananas... long wires, short wires...
Wonder if I should just wait for my Breed set from microdimitry.
Starting to miss a pickguard
03:50 AM
Ibateur
04-10-2008, 03:53 PM
Ibateur
Finally completed wiring this today. It doesn't look neat at all, but all pickups work as intended. Could have a grounding issue since if I let go of the metal parts, I get hum/buzz
I really like the protrack in the middle. It compliments the TZ (B) and PAFPRO I have quite well. Especially like the split coil tones. It is surprisingly louder than the JB Jr I used to have in there. I am surprised that it sounds so much like a humbucker as opposed to the single-coily sound of the JB Jr. The Protrack isn't very quacky.
Going to play around with it more. If anyone has questions, let me know.
Guitar is an RG570EX (basswood)
Ibateur
04-11-2008, 06:48 AM
Ibateur
Damnit, now that I've covered the control cavity, I've noticed that all coils (all 6) are sometimes on. Probably because some wires are touching each other now that they're all pressed into each other.
Rhymes with Duck, this...
Ibateur
04-16-2008, 03:37 AM
Ibateur
Finally works out.... Still waiting for my new pups from Dmitriy, but that'll come.
Next question, can I replace my tone pot to be a pushpull, with the result that pos 1, 3 and 5 are tapped (bridge, mid, neck)?
Ibateur
04-16-2008, 08:23 AM
Vim Fuego
If you connect the
coil tap
leads that go the the 5 way to the push pull pot as well, and the other side of the push pull pot to earth, that'll do what you want.
Jim
Vim Fuego
04-16-2008, 08:40 AM
Ibateur
Thanks Vim
I know I should search, but since I have your eyes ....
Can you let me know, 2K, 250K, 500K tone pot? Do I need to get any caps as well?
Thanks
08:47 AM
Ibateur
04-16-2008, 09:06 AM
Vim Fuego
The
Ibanez Jem
(according to the wiring diagram) uses a 0.022uF capacitor and a 500k log (audio) pot.
Jim
Vim Fuego
coil tap
ibanez jem
pole switch
wiring diagram
stereo output guitar mono how to electric wiring
stereo 2x12 wiring?
wiring guitars - what wire to use
how to install pickup in a strat diagram
Ibanez Guitar wiring?
serial # and wiring diagram on v7bsl
Jagermeistro
06:37 PM
ibanez wiring diagram different to actual guitar
Murray
Pickups & wiring
10:05 AM
JEM10th Evolution Wiring Diagram.....
gerca
Pickups & wiring
05:59 PM
1998 JS 1000 Wiring Diagram.
dfung
07:48 PM
Double Edge wiring diagram needed... - Changing pickups in S
armadillo
Tech: Setup, Repairs and Mods
10:04 AM
07:06 AM
