Old 04-12-2006, 09:38 AM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Wiring experts!! question about grounding
Hey guys, what can one do when everything is wired right, the cavity is shielded, and you still get "ground buzz"... it goes away as soon as you touch the bridge, or the strings or whatever, quiet as it can be.... but if you lift your hands away from the axe: bzzzzz!
I was wondering even if i could live with "oh well, it works ok when im touching the strigns", that wouldnt be the case with a hardtail or tom, cause i wouldnt have the trem wire to ground...
any "killing the buzz" tips?
thanx!
Old 04-12-2006, 10:25 AM
buddroyce  is offline
Re: Wiring experts!! question about grounding
It sounds like a ground loop where you're the one that's grounding off the signal. I would check your ground wires with a meter to make sure they're all making proper contact. If everything works all your ground connections should make contact to the ground on your output jack.
Look for cold solder joints and just redo them.
Old 04-12-2006, 10:42 AM
flarocks  is offline
Posts: 77  -  iTrader: (3)
Remeber that when grounding the controls in your guitar the best way to avoid ground loop is to solder all the grounds to a central pot or control. This will avoid the problem you have right now. Also, as stated earlier, check to make sure all of your joints are soldered correctly. I have done 1000's of wiring jobs and even I miss one once and a while! Good Luck.
Old 04-12-2006, 02:14 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
Is there a ground wire going from the back of one of the pots to the trem claw?
Old 04-12-2006, 02:22 PM
AleTheNervo  is offline
Posts: 459  -  iTrader: (0)
Try there it's in italian but has a lot of pics and diagrams
http://www.guitarmigi.it/tips/problemi-massa.aspx
trem claw
Question about RG570 wiring. Ranger-X Pickups & wiring 9 02-22-2005 06:24 AM
JEM10Th Wiring question. JEM10th Pickups & wiring 13 09-07-2004 07:27 PM
Guitar building question - How do they drill for the wiring? DirtyBird31 Tech: Setup, Repairs and Mods 3 04-23-2004 12:44 PM
Wiring - Question rephrased (easier to understand?) RG Guy Tech: Setup, Repairs and Mods 4 01-01-2002 12:56 PM
wiring question - internal connections 5 way selector switch GhesQi J Tech: Setup, Repairs and Mods 11 11-26-2001 05:49 PM
