Wiring guitar for 3 humbuckers - Jemsite
post #1 of 21 (permalink) Old 12-02-2011, 02:45 PM Thread Starter
Would it be possible to wire a guitar for 3 humbuckers using a threeway selector and olny one master volume??
llvulcanravenll is offline
post #2 of 21 (permalink) Old 12-02-2011, 03:02 PM
Reviews: 15
Re: Wiring guitar for 3 humbuckers
of course.
lespauled is offline
post #3 of 21 (permalink) Old 12-02-2011, 03:05 PM Thread Starter
Originally Posted by lespauled View Post
of course.
Thank you, I'm a noob when it comes to this stuff
post #4 of 21 (permalink) Old 12-02-2011, 04:18 PM
easy, just wire the live wire from each pickup to the switch,
one wire from the switch output to the vol pot,
one wire from the vol pot to the jack.
connect all the ground wires to earth (usually a blob of solder on the vol pot)
I usually dont bother with tone pots, dont see the point and they dont do anything you cant do better with pedals or DAW's.
LostInRockFormations is offline
post #5 of 21 (permalink) Old 12-02-2011, 06:14 PM
sounds sexy . please post pics when done!
GUITARMAGEDDON is offline
post #6 of 21 (permalink) Old 12-02-2011, 08:01 PM
Reviews: 98
Ahem, you missed this thread:
Another pickup wiring resource thread!
You might be better off with a multi-pole 5-way switch, though.
Here's the diagram you need--eliminate the tone pot:
AlaskaBat is offline
post #7 of 21 (permalink) Old 11-09-2012, 11:03 PM
Its what Im doing also ....Im gonna have full power down, middle out of phase (try to) & up will be neck pickup.
2DECADESSOFAR is offline
post #8 of 21 (permalink) Old 11-09-2012, 11:21 PM
Whats all this NORTH & SOUTH crap about ...start & finish. I find my hot wire & ground wire & go from there.
post #9 of 21 (permalink) Old 11-10-2012, 01:40 AM
Reviews: 15
Pickups use magnets. The ends of the magnets are called poles, hence there are north and south poles.
silverctr is offline
post #10 of 21 (permalink) Old 11-10-2012, 08:07 PM
How are we suppose to determine accurately which is which when the pickups are wrapped?
post #11 of 21 (permalink) Old 11-10-2012, 09:12 PM
Reviews: 120
Compass maybe?
LonePhantom is offline
post #12 of 21 (permalink) Old 11-11-2012, 04:34 PM
Reviews: 11
You'll have to draw a map. Then go outside on a windy day. Face the wind and spit. If it hits you in the face, then you're going North. Wire accordingly from there.
D.M.RG7620 is offline
post #13 of 21 (permalink) Old 11-11-2012, 05:45 PM
Reviews: 15
The manufacturer usually has color codes to ID the poles.
post #14 of 21 (permalink) Old 11-11-2012, 09:51 PM
Well,thats whats sorta confusing ............ Theres HOT & Ground, Theres Positive & negative, theres North & South, I'll ASSume theese all basically mean the same thing. Im assuming. Just dont see why they call it NORTH instead of HOT or Pos. .... Its bad enuff when dealing with 4,5 & sometimes up to 10 wires, they should have a simpler more set method of describing a hot wire,IMO
post #15 of 21 (permalink) Old 11-12-2012, 02:06 AM
Reviews: 15
For the most part they mean the same thing. I think the ones that say hot/ground usually deal with single conductor pickups (including some humbuckers). When you're dealing with 4 conductor pickups, then the north/south, positive/negative are more useful since you're most likely splitting coils, or wiring for series/parallel, etc.
I do agree that it can be confusing and extremely aggravating because it seems so simple sometimes and other times it feels like you need an electrical engineering degree.
3 humbuckers
Human Verification
Perfect Wiring for 3 Humbuckers? Malstrom Pickups & wiring 16 12-11-2009 12:19 AM
Wiring help with H-S-H - Need humbuckers on in 2 and 4 posit 6828 Tech: Setup, Repairs and Mods 6 12-08-2009 02:54 PM
suggestions for wiring 2 humbuckers & 5/way john1880 Pickups & wiring 5 09-08-2006 10:35 AM
Jem-Like wiring from two Humbuckers? MicJustMic Pickups & wiring 2 06-05-2003 08:26 PM
5way Wiring 2 Humbuckers ScottRosenberger Pickups & wiring 5 02-11-2003 09:59 AM
