Pickups & wiring
Wiring guitar for 3 humbuckers
Pickups & wiring
12-02-2011, 02:45 PM
llvulcanravenll
Posts: 73 - iTrader: (
Would it be possible to wire a guitar for
3 humbuckers
using a threeway selector and olny one master volume??
llvulcanravenll
Find all posts by llvulcanravenll
12-02-2011, 03:02 PM
lespauled
Posts: 296 - iTrader: (
Reviews: 13
Re: Wiring guitar for 3 humbuckers
of course.
lespauled
Find all posts by lespauled
12-02-2011, 03:05 PM
llvulcanravenll
lespauled
of course.
Thank you, I'm a noob when it comes to this stuff
llvulcanravenll
12-02-2011, 04:18 PM
LostInRockFormations
Posts: 211 - iTrader: (
easy, just wire the live wire from each pickup to the switch,
one wire from the switch output to the vol pot,
one wire from the vol pot to the jack.
connect all the ground wires to earth (usually a blob of solder on the vol pot)
I usually dont bother with tone pots, dont see the point and they dont do anything you cant do better with pedals or DAW's.
Find all posts by LostInRockFormations
12-02-2011, 06:14 PM
GUITARMAGEDDON
Posts: 1,236 - iTrader: (
llvulcanravenll
Would it be possible to wire a guitar for 3 humbuckers using a threeway selector and olny one master volume??
sounds sexy . please post pics when done!
GUITARMAGEDDON
Find all posts by GUITARMAGEDDON
12-02-2011, 08:01 PM
AlaskaBat
Contributor
Posts: 8,948 - iTrader: (
Reviews: 98
Ahem, you missed this thread:
http://www.jemsite.com/forums/f35/an...ad-110579.html
You might be better off with a multi-pole 5-way switch, though.
Here's the diagram you need--eliminate the tone pot:
AlaskaBat
Find all posts by AlaskaBat
11-09-2012, 11:03 PM
2DECADESSOFAR
Posts: 347 - iTrader: (
Its what Im doing also ....Im gonna have full power down, middle out of phase (try to) & up will be neck pickup.
2DECADESSOFAR
Find all posts by 2DECADESSOFAR
11-09-2012, 11:21 PM
2DECADESSOFAR
Whats all this NORTH & SOUTH crap about ...start & finish. I find my hot wire & ground wire & go from there.
2DECADESSOFAR
11-10-2012, 01:40 AM
silverctr
Posts: 880 - iTrader: (
Reviews: 15
2DECADESSOFAR
Pickups use magnets. The ends of the magnets are called poles, hence there are north and south poles.
silverctr
Find all posts by silverctr
11-10-2012, 08:07 PM
2DECADESSOFAR
How are we suppose to determine accurately which is which when the pickups are wrapped?
2DECADESSOFAR
11-10-2012, 09:12 PM
LonePhantom
Posts: 7,201 - iTrader: (
Reviews: 120
Compass maybe?
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
11-11-2012, 04:34 PM
D.M.RG7620
Posts: 2,748 - iTrader: (
Reviews: 11
You'll have to draw a map. Then go outside on a windy day. Face the wind and spit. If it hits you in the face, then you're going North. Wire accordingly from there.
D.M.RG7620
Find all posts by D.M.RG7620
11-11-2012, 05:45 PM
silverctr
Reviews: 15
2DECADESSOFAR
The manufacturer usually has color codes to ID the poles.
silverctr
11-11-2012, 09:51 PM
2DECADESSOFAR
silverctr
Well,thats whats sorta confusing ............ Theres HOT & Ground, Theres Positive & negative, theres North & South, I'll ASSume theese all basically mean the same thing. Im assuming. Just dont see why they call it NORTH instead of HOT or Pos. .... Its bad enuff when dealing with 4,5 & sometimes up to 10 wires, they should have a simpler more set method of describing a hot wire,IMO
2DECADESSOFAR
11-12-2012, 02:06 AM
silverctr
Reviews: 15
For the most part they mean the same thing. I think the ones that say hot/ground usually deal with single conductor pickups (including some humbuckers). When you're dealing with 4 conductor pickups, then the north/south, positive/negative are more useful since you're most likely splitting coils, or wiring for series/parallel, etc.
I do agree that it can be confusing and extremely aggravating because it seems so simple sometimes and other times it feels like you need an electrical engineering degree.
silverctr
3 humbuckers
Perfect Wiring for 3 Humbuckers?
Malstrom
Pickups & wiring
12:19 AM
Wiring help with H-S-H - Need humbuckers on in 2 and 4 posit
6828
Tech: Setup, Repairs and Mods
02:54 PM
suggestions for wiring 2 humbuckers & 5/way
john1880
Pickups & wiring
10:35 AM
Jem-Like wiring from two Humbuckers?
MicJustMic
Pickups & wiring
08:26 PM
5way Wiring 2 Humbuckers
ScottRosenberger
Pickups & wiring
09:59 AM
09:17 PM
