Old 08-29-2007, 08:17 PM
ryank  is offline
Posts: 20  -  iTrader: (1)
Wiring help! 2 hums, 3 way blade, 1 vol
I'm fixing the electronics on my friend's 540pii and it is pretty much impossible to tell how it used to be wired up. Can anyone help?
Both humbuckers are the DiMarzio-made IBZUSA pickups with 4 conductors. The 3 way blade has 8 leads on it.
Also, what is the middle position supposed to do? Turn both pickups on? If that's the case, I think I would rather wire it up like a JPM so it has a nice hum-cancelling single coilish sound.
If anyone can help, it would be much appreciated (by at least two people!)
Old 08-29-2007, 10:29 PM
ryank  is offline
Re: Wiring help! 2 hums, 3 way blade, 1 vol
And does anyone know if this thing was supposed to come with a 500k or 250k volume pot? Thanks in advance!
Old 08-30-2007, 11:18 AM
Devo  is offline
Posts: 1,483  -  iTrader: (20)
it would be more normal to go for 500k pots in a humbucking guitar
If you had a pic of the switch then I could draw you a diagram for whatever pickup config you wanted
Best wishes
Steve
Old 08-30-2007, 12:24 PM
ryank  is offline
Just curious since there's no tone pot, I heard there might be even more high-end using a 500k for the volume.
Thanks!
Old 08-30-2007, 05:34 PM
ryank  is offline
You know what, I just helped myself.
First time Korn's ever been good for anything. lol (the split coil config is easy enough to figure out now):
Old 08-31-2007, 01:35 AM
ryank  is offline
And for future reference for the Internet, RG565 owners, etc...
(if the poles are 1-8 from left to right)
Neck position turns on pole 3 and the middle two
Bridge position turns on pole 6 and the middle two
The middle position turns on pole 2,7, and the middle two
bridge position, neck position
need help asap with mini switch dp/dt on/on/on for pickup wiring 2 hums ibanezcollector Pickups & wiring 2 07-09-2007 05:30 AM
Building wiring scheme with 3 hums dope_maggot Pickups & wiring 1 12-30-2006 04:06 PM
Ibanez jem alternate stock wiring method??! Ki swordsman Pickups & wiring 7 11-24-2005 07:31 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 06:26 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
