Old 11-16-2007, 10:16 PM
kadeks  is offline
Posts: 18  -  iTrader: (0)
Wiring help
I'm thinking about messing around with my RG350's wiring, and I'd appreciate some help before I do something stupid.
How would this work:
3 volume push/pulls, one for each pickup for coil tap or series/parallel
1 master tone.
5 way switch
How would I go about doing this? It seems like I would make some kind of illegal loop with all the volume pots going to the same tone pot. I haven't done very much wiring but this seems straightforward enough.
My pickups are Evolution neck in the neck, Evo 2 in the bridge, and pro track in the mid. Should I use 250k pots or 500k pots, and what's the difference?
Should I use coil tap or series/parallel with my pickups? And would using either sound good with a single coil sized humbucker like the pro track? I've only been using coil taps so far because it is easier to wire, but I don't know much about series/parallel. And is it possible to split the neck and middle pickups at the same time with the same push/pull pot, and split the middle and bridge pickups at the same time with another push pull pot?
Would 4 push/pull pots fit in the small cavity? And how would I drill a clean hole in my pickguard? I drilled a hole in a 3-ply pickguard before, but it looked terrible. I drilled it too small because I didn't have a large enough drill bit and thought I could sand it down to size. I sanded it for a good half hour before I could fit it in. >_<
Thanks.
Last edited by kadeks; 11-17-2007 at 08:55 PM. Reason: Forgot to include a question
bridge pickup, bridge pickups, coil tap, evolution neck, master tone, ply pickguard, volume pots
JS1 ('90/'91) Volume Pot Wiring / Wiring Model? guitarboy JS (Satriani Model) Ibanez Guitars 0 01-14-2007 05:31 AM
Building wiring scheme with 3 hums dope_maggot Pickups & wiring 1 12-30-2006 04:06 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 06:26 PM
Wiring for an RG Allen Garrow Other 7-string Guitars 5 06-29-2004 06:45 AM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
