Old 12-20-2008, 04:29 PM
GuitarEvan07  is offline
Posts: 666  -  iTrader: (16)
Wiring issue. Probably easy to fix. Help me real quick
Ok guys, replacing the stock bridge pup on my Ibanez S470 with a Dimarzio Paf Pro. Ive replaced pickups before but this is giving me a hard time.
Getting a bunch of feedback and the pickup just doesnt sound right(just snappy sounding. Its not like the common almost clean sounding problem.)
This is how I have it wired:
(view: guitar flipped over):
Green and bare to the ground on the volume pot.
Red to the third pole from the right on the switch
White to the last pole(8th) from the right
Black is just hangin around to be honest. Wherever I soldered it it didnt seem to change anything.
Any help would be great!
Thanks!
Old 12-20-2008, 04:40 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: Wiring issue. Probably easy to fix. Help me real quick
solder the black and white together.
if you have a problem after that leave the black and white together but remove them from the switch, dont let me ground anywhere through.
with the B/W together taped off the pickup should be running flat out in series no probs..
if it still sounds crap then give us more info..
Old 12-20-2008, 07:55 PM
I just tried both and now its not working at all. Ughh very little lead wire to work with. came with only like 2 and a half to 3. I think I might just put the old pickup back in and sell this one and buy one with more lead wire.
Thanks for the help though.
Old 12-21-2008, 06:00 AM
Jaden  is offline
extend the leads on the pickup by soldering inline wires onto it..
dimarzio paf pro
Prob Easy help with wiring diagram brain21 Pickups & wiring 0 12-15-2008 12:27 PM
JEM Wiring issue! Help! GuitarEvan07 JEM and Universe Guitars 1 02-16-2008 11:41 PM
Wiring Issue Code001 Pickups & wiring 4 05-15-2006 03:05 PM
need help quick....easy question kennydoe Pickups & wiring 4 01-20-2004 10:16 PM
Real quick..mm"s *converted to 50th's of an inch.. - help me badwamajama Tech: Setup, Repairs and Mods 3 12-22-2000 12:59 PM
