Old 01-16-2009, 11:49 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
Wiring Problem...crap...
alright guys I need help troubleshooting this.
I wired in some Seymour Duncan Blackouts into my guitar and everything works except this small problem.
roll the volume to 0 and then when the tone is at 10 there is no sound but as you roll the tone back it increases volume.... don't understand how this could've happened.
I've gone over the diagram they provided AND triple checked all my soldering leads with a multimeter to make sure everything is proper.
can't figure it out for the life of me... can anybody help?
this is my wiring diagram: http://www.seymourduncan.com/support...kouts_1v_1t_3w
Old 01-17-2009, 02:15 AM
Pursuit  is offline
Posts: 680  -  iTrader: (0)
Re: Wiring Problem...crap...
Well if the Volume is doing pretty much nothing and the tone is controlling volume, maybe you've put them wrong way around AND put the volume (in the tone hole) backwards lol.
Old 01-17-2009, 10:55 PM
volume works fine
when volume is at 0 the tone knob can act as a volume control somehow... but it still affects the tone when the volume is rolled up to 100%
so let's recap again
volume at 100% - tone knob works fine (as far as I can tell)
volume at 0% - tone knob increases volume as you roll it down to 0 from 100%
Old 01-18-2009, 12:13 AM
EvoGiant  is offline
Posts: 355  -  iTrader: (2)
i would check to make sure i used the right lugs on the pots. sounds like somethin is crossed up there. make sure the ground from the vol to the tone is good too..
Old 01-18-2009, 05:11 AM
well even though the multimeter was working the solder joint might not have been.
after remelted the solder on the ground wires it now works 100% perfect.
thanks guys.
http://www.jemsite.com/forums/f17/js...ion-86012.html
Old 01-18-2009, 11:22 AM
EvoGiant  is offline
cool. sucks how something so tiny can cause such a pain.
Old 10-12-2009, 12:00 AM
Emilcom  is offline
Posts: 3  -  iTrader: (0)
Arrow
Hello;
I am installing the same pickups with the same diagram into a Schecter guitar. This is my first time doing it and I have a problem.
I do not know what is the bare wire, where does it come from? Do i get to weld it into the pickup connection?
Can you help me please?
Thanks a lot in advance
Old 10-12-2009, 04:02 AM
soultech76  is offline
Posts: 17  -  iTrader: (1)
Originally Posted by Emilcom View Post
Hello;
for some reason i didnt see the op or the few after it at first. ok bare wire is ground. it comes from the pickup so no you dont weld(lol) it to the pickup. btw the term is solder.
Wiring problem? DotNetTim Pickups & wiring 1 06-19-2005 12:26 AM
jem wiring problem :( help! tonluvara Pickups & wiring 5 08-13-2004 05:27 AM
Help!!! H-S-H Wiring Problem SBlack Pickups & wiring 2 09-03-2003 06:51 PM
I have a wiring problem..... jeff l Pickups & wiring 4 04-01-2003 09:27 AM
EMG wiring problem, please help!!! mingincorn Pickups & wiring 1 11-25-2002 05:09 PM
