Old 07-19-2005, 01:07 PM
Christoph_JEM  is offline
Posts: 73  -  iTrader: (0)
Question
Wiring problems with Seymour Duncan in a JEM
Hi everybody!
A friend of mine bought a Seymour Duncan in order to replace the DiMarzio Breed in bridge position. The guitar is a JEM7DBK. He soldered the wires from the Seymour Duncan exactly as the DiMarzio was soldered to the 5-way switch (VLX91). This means the red wire was soldered to exact place where the red wire from the DiMarzio was soldered to. But in position 1 (full humbucker mode) the sound was quite bad. Very trebly, sharp and not much output.
Last weekend we experimented a little bit and solved the problem in position 1. But now the same problem appears in position 2 (inner coil from the humbucker combined with the single coil). The sound is very sharp, thin and has even much less output than the single coil has (position 3). We think that position 2 is "out of phase". We tried several wirings, but could not solve this problem. Can anyone imagine what we did wrong?
I have attached a wiring diagram in which you can see how we wired the pickup right now. In the manual that came with the Seymour Duncan, there is some information you might need:
green = beginning of adjustable coil (South)
red = finish of adjustable coil
black = beginning of stud coil (North)
white = finish of stud coil
Adjustable coil = south magnetic polaritiy
Stud coil = north magnetic polarity.
The adjustable coil points towards the bridge (the one on which "Seymour Duncan is printed on).
IŽd be very glad if someone could help us with that issue!
Thanks in advance ;-)
Greetings,
Christoph.
Old 07-19-2005, 03:27 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Re: Wiring problems with Seymour Duncan in a JEM
Well you need to sort out your colors youve used the wrong ones, you should get schematics from Seymour duncans website, since the colors are different. This kind of sucks for dimarzio and duncan users and i wish they would standardize it to match
Old 07-19-2005, 03:57 PM
Toto  is offline
Posts: 313  -  iTrader: (0)
http://www.guitarelectronics.com/cat...kupcolorcodes/
check this out man! here are all color codes for many many different PUs
Old 07-21-2005, 03:08 AM
pinto79  is offline
Posts: 371  -  iTrader: (4)
He may have to reverse the phase of one of the pups too. to do that, switch the hot wire with the coloured one that goes to ground.
Old 08-08-2005, 05:35 AM
guitarshredder7  is offline
Posts: 610  -  iTrader: (0)
yeah reverse the phase of it. just take your time and you will figure it out
Old 04-14-2011, 05:24 PM
Darkmadder667  is offline
Posts: 1  -  iTrader: (0)
Thanks, I just installed some JB's and they sounded tinny and i wasnt able to get any sqeals/harmonics. I did what you suggested and now it sounds great! Thankx
Old 04-14-2011, 05:45 PM
AlaskaBat  is offline
Contributor
Posts: 6,645  -  iTrader: (17)
Images: 11
Reviews: 94
Great to see a 6-year old thread still helping people...
bridge position, dimarzio breed, seymour duncan, seymour duncans, wiring diagram
JPM Wiring on a jEM. HELP!!!!! Marcelo Pickups & wiring 7 08-16-2004 11:32 AM
finished wiring but have problems, please help! jpwannabe Pickups & wiring 2 07-13-2004 08:37 AM
Seymour Duncan JB on JEMs...any opinions? - Have a TB-4 JB H trouble311 JEM and Universe Guitars 2 08-04-2001 04:34 PM
Wiring problems.... - the wires' colors are driving me crazy yuza Tech: Setup, Repairs and Mods 9 02-15-2001 09:53 AM
