Old 02-10-2006, 12:14 PM
jclogston  is offline
Posts: 456  -  iTrader: (4)
Wiring push/push pot and Soldering Kit Question..
Hi everyone -
Just a quick question.
I just received a jazz neck that i want to install in my guitar. I also want to replace my push/pull pot with a push/push.
I think i want to try it myself as i do want to pay another $60 to get this done.
Does this kit contain everything i need?
http://www.radioshack.com/product/in...entPage=search
Also, would the wiring be the same for the push/push pot as the push/pull pot?
thanks
jeff
Old 02-11-2006, 07:01 PM
buddroyce  is offline
Re: Wiring push/push pot and Soldering Kit Question..
It looks like there's everything you need to get started on wiring except that you may want to get a small roll of electronic wire if you want to start getting some fancy wiring going. Wiring a push/push pot is the same as a push/pull pot. The only difference is the spring mechanism in which you change poles.
I probably wouldn't suggest using a push/push pot to select pickups unless you want to wire some sort of LED indicator to show you which pickup is active. (now that's a pretty cool/stupid idea I should try!)
Old 02-20-2006, 10:59 PM
Champagne Mist  is offline
Posts: 153  -  iTrader: (0)
some solder wick might be handy in case you need to unsolder something
and a wet sponge is always helpful for cleaning off the iron tip
