Pickups & wiring
X2N and Paf Pro?
Pickups & wiring
10-19-2005, 07:22 AM
isida.d
Posts: 299 - iTrader: (
X2N and Paf Pro?
Is a X2n in the bridge and a
Paf pro
in the neck a good combination for hard rock and metal?
I'm told the X2n is a very high powered pickup that can really scream and the paf pro is a good building block pickup for any combination that just adds some good diversity to any setup.
oppinons?
thanks
isida.d
Find all posts by isida.d
10-19-2005, 02:06 PM
frankfalbo
Posts: 1,875 - iTrader: (
Re: X2N and Paf Pro?
Yeah that's fine. The X2N will out-power the PAF Pro, but it's not really a bad thing. If you coil cut them when they're on together (either automatically or with an additional switch) you should get a good, usable cleaner sound with some output drop, but in a good way. I'm not a fan of the X2N, so without knowing what you play and what your amp is, it's hard to say whether these would be the BEST pickups for you personally, but it's totally a valid combination IMO.
BUT...Here's a thought. One pickup that I love in the neck is the Megadrive. It has one bar magnet coil, like the X2N, and one allen pole coil. It was marketed as a
bridge pickup
but I feel it's a little to trebly for the bridge. Plus each coil is very different from the other. The bar coil is loud and fat, while the pole coil is clean and glassy. It is higher output, though, so it should be combined with a higher output bridge pickup. In your case, the X2N is about as hot as they come. An X2N/Megadrive combo woul dbe super cool IMO. Dimarzio doesn't advertise the Megadrive, but they'll probably let you order one. Even if they don't, I know several places to find used ones.
frankfalbo
Find all posts by frankfalbo
10-19-2005, 08:07 PM
isida.d
I play metal mostly but i like to have a pickup that sounds OK clean aswell becuase even tho i'm a metal head i like to play less heavy stuff aswell with clearer tones i guess. You could pretty much call me a metal head who has a open mind in music. I'm into jazz and classical aswell as metal. Maybe i went a bit overkill with the idea of the X2N i am not sure.
AMP wise i use peavey amps at the moment but in the future i'm going to get a line6 spider.
CUrrently i use the transtube series of peavey amps. Currently i only have 1 guitar but its a
mahogany body
and a
fixed bridge
with a maple neck from what i understand and its a set in neck rather than a bolt on. Put simply its a SZ520 Except it was a earlier production one so it didnt come with Duncan/ibanez pickups.
I'm kinda new to this gear stuff and knowledge of it but i've been reading up on sites to learn. And this will be the first time i've ever gotten pickups upgraded in a guitar and i guess i was looking for something diverse. I'd prefer to stay away from active pickups tho they seem tedious to me becuase i dont know if my guitar can be set up so teh batteries are easy to change but i'd prefer just to stay away from them fullstop.
isida.d
10-19-2005, 09:17 PM
eelblack2
Posts: 865 - iTrader: (
Ive been digging Duncans in the neck lately and Dimarzios in the bridge. Maybe peak at the SD site and see if anything jumps out at you.
eelblack2
Find all posts by eelblack2
10-19-2005, 10:07 PM
Shredcows
Posts: 506 - iTrader: (
Hmmm... I don't find the X2N having a very bland, sterile
clean tone
like high gain EMGs. Yes, the clean is very compressed but there is a measure of dynamics there still; it works out great for funk (when split) or when doodling some clean jazz lines with your tone rolled down. The thing is, for jazz, the X2N makes the thinner strings balance out nicely with the rest, which is always a problem if you use thin strings.
As for the X2N pushing everythign into overdrive... Just don't jam it too close to the strings.
You don't need THAT much overdrive do you?
I used a X2N and a Humbucker From Hell together before, and i managed to balanced the 2 together volume-wise. Granted, I had to lower my X2N considerably but in the end, things were fine.
I don't think you'll find a problem balancing the PAF Pro with the X2N.
I have done a recording of the X2N in a mahogany guitar, an S520EX here:
X2N Showcase
Its all X2N on rhythm and lead. S520EX running into an Ibanez TS9DX then Boss SD-2 and to the JC Clean of a Roland Microcube, finally into my PC.
I can safely say, you put an X2N into the thick mahogany body of the SZ, expect a really crushing tone.
Shredcows
Visit Shredcows's homepage!
Find all posts by Shredcows
10-20-2005, 04:55 AM
isida.d
OH MY GOD
i LOVE that tone.... i so want that pickup now more than i did before.
If i may ask , for that clip what amps and distortion pedals and effects did you use?
05:25 AM
isida.d
10-20-2005, 06:01 AM
Shredcows
Hey man... heh... I listed the efx and amps there already.
Its a S520EX running into an Ibanez TS9DX then Boss SD-2 and to the JC Clean of a Roland Microcube, finally into my PC.
Thats it. Pretty rudimentry but you get the idea how tight the X2N is.
Shredcows
10-20-2005, 06:53 AM
isida.d
gah sorry i kinda saw your approval of the paf pro x2n combo then went OOOOO clip so i listened to it.
I shoulda read the message properly...
i feel stupid now lol sorry abou that.
Your good...i've been learning
sweep picking
lately... i need to find some good exercises tho.
isida.d
10-20-2005, 07:43 PM
Praetorian
Posts: 422 - iTrader: (
I used to have an X2N in my old RG550, I wanted a bit more crunch so I opted for Evos. Now, this may sound crazy, but try putting a
Tone Zone
in the neck with the X2N in the bridge and you'll get a good neck sound with power to match the X2N. The PAF Pro in the neck is a good all around pup but it's not fantastic and doesn't have the characteristic I like in a
neck pup
. I much prefer the Evo neck but that's definately not enough power to balance with an X2N.
Praetorian
Visit Praetorian's homepage!
Find all posts by Praetorian
10-20-2005, 07:50 PM
isida.d
i actually heard that
michael romeo
from symphony x uses that combination. I'm just trying to get some decent clean tones aswell ig uess. Hmm
isida.d
10-20-2005, 09:23 PM
Shredcows
I have used a Tonezone in the neck before... its ultra FAT. Its so fat (on my S520) that its to the point of being ridiculous. This made is awesome for hi gain leads since the higher you go, the notes still have good body... and of course, its great for jazz. The cleans are just as thicker. However, don't hope to strum around with it. Its too thick for that... even on split, when you select the coil with the flat pole pieces, thats the warm, fat coil. If you hope to get a nice split sound, you have to split to the coil with adjustable screw heads.
Actually, when you guys say the pup doesn't balance, you are talking in terms of volume or output/saturation?
Shredcows
10-20-2005, 09:36 PM
isida.d
hmmm just trying to find a good combination pickup to go with the X2N is all.
isida.d
10-20-2005, 11:12 PM
Praetorian
well, the output sort of is the volume, it's like comparing an
Evo bridge
to a PAF Pro in the bridge, the Evo is obviously louder because it's almost twice the output. The Evo neck however is about the same output. Personally the Evo neck is my favorite neck pup, I think it sounds amazing. Just remember, the
neck position
is naturally louder than the bridge so you don't need as much output in the neck as in the bridge. The TZ is incredibly fat but has the power to balance with the X2N. If you don't like it though, the PAF Pro will balance well too, I'm just saying I think it's very so-so, don't expect amazing things out of it because it's made to cover every ground, not to excel in one area. It's mainly personal preference.
Praetorian
10-20-2005, 11:45 PM
toshiro
Posts: 1,812 - iTrader: (
I have an Air Norton/X2N set-up in my S540, matches up pretty well. If I wanted something a little hotter for the neck, I'd go for a regular Norton over the Tone-Zone, simply because it has less bass and gain.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
10-21-2005, 12:18 AM
isida.d
would a evo neck work well too?
isida.d
air norton
bridge pickup
bridge pup
clean tone
coil split
distortion pedal
evo bridge
fixed bridge
heavy metal
ibanez pickups
mahogany body
maple neck
michael romeo
neck position
neck pup
paf pro
peavey amp
pickup combination
sweep picking
tone zone
high output pickups vs low output pickups
body-mounted pickups vs. pickguard mounted pickups
compare fender vintage noiseless strat pickups and vintage hot noiseless strat pickups
HSS pickups guitar pickups
10:11 PM
