Old 04-15-2007, 09:07 AM
_MKK_  is offline
Posts: 155  -  iTrader: (4)
X2N bridge, TZ neck..what single coil?
Hi!
I want to change the pickups on my rg550ex..
I've read that the x2n at the bridge and the ToneZone in the neck is a killer combo ( i play mostly rock/metal), but what can i choose for the single coil?
I'm searching for something good also for clean rythmics (like funky etc..)
Thanks!
Old 04-15-2007, 01:22 PM
_FR0D0  is offline
Posts: 528  -  iTrader: (0)
Re: X2N bridge, TZ neck..what single coil?
that combo is good for metal and only metal. If you want something more versatile having rock and funk sounds I suggest using a Evo 2 (B), reverse Blue Velvet Bridge(M), Air Norton (N).
But if you like to go with X2N + TZ, put a Red Velvet in the middle
Old 04-19-2007, 06:59 PM
_MKK_  is offline
I try to don't open another thread!
I found a lot of difficulty to find a good dimarzio dealer that ships outside USA, so i think to get a seymour duncan neck pickup to use with the x2n on the bridge..what model should i buy (always for metal\rock genre)?
Thanks!
air norton, blue velvet bridge, neck pickup, seymour duncan
Single Coil Replacements Thrash Pickups & wiring 2 08-29-2006 01:22 PM
Breed neck / bridge difference in bridge position marino Pickups & wiring 2 05-25-2005 09:43 PM
7 strings, 2 hum + single coil ... i need an EMG solution! skattabrain Pickups & wiring 0 11-01-2004 10:53 PM
Replacement Single Coil for BFP? Dunadan Pickups & wiring 6 07-05-2004 12:22 AM
Finally found a 7 string Single Coil - ...installed it today kennydoe JEM and Universe Guitars 0 04-12-2001 04:34 AM
