<back   Jemsite > Players, People, Music and Tours > Dave Weiner Official Forum Archive (SEE NEW LOCATION)
Dave Weiner Official Forum Archive (SEE NEW LOCATION) This forum area is now closed. Go to Dave's new dedicated forum on daveweiner.com.
Old 08-07-2005, 10:32 PM
purplehaze21  is offline
Posts: 3  -  iTrader: (0)
Unhappy
Bending
I am having a lot of problems bending, with making the transition from having the strings I'm bending up into (say B and G if I'm bending E) be pushed up - essentially "grabbed" by the area right below my fingernails and having them slip under my fingertips. I need to be able to do it so there is no excess noise, and it feels right. My action is fairly high so it's not my guitar. I was wondering if anybody had any insight for this- I already use right hand muting etc.. Plus I heard Dave uses very low action and I was wondering what his bending technique is. I've made many threads about this in other forums so I doubt I'll get anything here to solve my problems, but it's worth a try. Thanks.
Old 08-08-2005, 12:36 AM
Bahamut  is offline
Posts: 311  -  iTrader: (1)
Re: Bending
I tend to mute the surrounding strings with my left hand... Say i'm bending the G string (Don't laugh) with my ring and middle fingers then I'll lay my index finger over the strings surrounding that string to mute it a bit. Not much, just enough to keep it from ringing out...
Try it! Might help !
Old 08-08-2005, 01:49 AM
vette6600  is offline
Posts: 881  -  iTrader: (0)
Re: Bending
i used to have the same problem. i found that when i was pushing/bending my g-string (i encourage your laughter) to my D, G actually ended up underneath it, so when i came back down, i was grabbing the D by accident. hope that makes sense. if not, too bad because im lazy!
Old 08-08-2005, 12:17 PM
DavejWeiner  is offline
Posts: 718  -  iTrader: (10)
Re: Bending
I judge my action by bending. If the bent string is going under another, the action is too high. If it's being bent into another string, then the action is fine.
Old 08-08-2005, 12:32 PM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Re: Bending
Couldn't have said it better, nice Dave .
Regards
André
Old 08-09-2005, 11:10 AM
Re: Bending
What do you mean when you say bent into another string? Like the strings you bend up into are basically on the fretboard and under your fingertips as well?
Old 08-09-2005, 11:16 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Re: Bending
Meaning when you bend the string, say high E - does it touch (bend directly into the B) or does it go UNDER or over the B.
Old 08-09-2005, 12:05 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Re: Bending
Doesnt steve us a fairly high action though dave? Maybe you could clear this ideal up for us, as the old pictures of evo on vai.com show an action i would estimate at being around 4mm high at the 12th fret allowing for maxium pull up range of every note on the fretboard
Old 08-09-2005, 12:42 PM
Re: Bending
Steve's action seems pretty low to me.
Old 08-09-2005, 05:09 PM
Re: Bending
Sniperfrommars, is that action you said of 4 mm from the wood or the frets?
Old 08-10-2005, 02:59 AM
fettouhi  is offline
Re: Bending
Seems quite high the action.
Kind Regards
André
floyd rose moves when bending a string bujecas Tech: Setup, Repairs and Mods 17 09-01-2008 07:46 AM
Bending Rash Guitar Lessons & Music Theory 3 02-11-2004 07:53 PM
question about neck bow, and bending strings. davester1234 Tech: Setup, Repairs and Mods 9 06-12-2003 01:16 AM
JS + JEM owners, need info - Action, string bending comparis YngVaiTriani Tech: Setup, Repairs and Mods 11 02-25-2002 05:25 PM
High E is too tight. - bending this string is a bugger Vai the god of Sound Other 6-string Guitars (non-Ibanez brand) 8 01-14-2002 08:15 AM
